rsorg Posted April 9, 2016 Share Posted April 9, 2016 After changing my trans fluid ,I noticed that the 2 wire connection on the drivers side( turbo 400 trans )keeps on coming off ,real loose ,is there suppose to be some kind of a clip to keep the rubber grommet on the white/clear plastic piece ,i used a zip tie around the rubber boot but does not stay on very good, is there something out there I could buy or create ,to keep this on ,thanks Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 9, 2016 Share Posted April 9, 2016 Sounds like the ends inside the connector has worn. You could cut the original end off and put two new ends on the wire. Being a 400 you do need those wires as it is the elec kick down for the trans Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 9, 2016 Author Share Posted April 9, 2016 The end is the original rubber boot, does anyone make a new rubber end ,? I hope that is the reason why ,when I gas it the passing gear does not kick in. and after replacing fluid I drained out 3 quarts ,but added 5 to have the dipstick now read ,full, but have not had a chance to see if the kick down\passing gear will work now,plan on driving it today, thanks Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 9, 2016 Share Posted April 9, 2016 I might have a plug from the last two re-wiring I have done. Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 9, 2016 Author Share Posted April 9, 2016 let me know if you would like to sell one ,I am thinking that my kick down is not working because of this ,thanks Quote Link to comment Share on other sites More sharing options...
monte70car Posted April 10, 2016 Share Posted April 10, 2016 Here is what I have for the 400 trans. It is a single wire unit the needs a ground put in it. Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 17, 2016 Author Share Posted April 17, 2016 I am going to replace the kick down switch by the gas pedal, I believe that is why my passing gear is not working ,thanks Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted April 17, 2016 Share Posted April 17, 2016 You might try re calibrating the kick down switch 1st. It may be your switch just lost it's calibration and needs to be reset. I wished I could clearly remember how to reset, but was a pretty simple operation to do, just can't trust myself to remember the procedures exactly. If switch lost power during operation of car , may have triggered switch to forget when plugged back in?............................... Doug Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 19, 2016 Author Share Posted April 19, 2016 I ordered a new switch, hopes this clears up my kick down, passing gear issues, thanks Quote Link to comment Share on other sites More sharing options...
rsorg Posted April 24, 2016 Author Share Posted April 24, 2016 The new switch works great now ,the passing gear kicks in like it suppose to ,NICE Quote Link to comment Share on other sites More sharing options...
