A/C question
Leghome
Bob what is the factory fill? There are no stickers or any kind of info on the car at all. Did a google search and found that the factory was set at 3.25 lbs. So between 2.6 and 2.75 lbs should do it.
That's correct, Also check dryer is it sweating? An output temp at right side vent at 43 degrees is great at mid seventy outside temp at 1300 rpms door open. should be able to find a chart online. at higher outside temps ( measured at front of grill a couple inches out) adjust output a higher temp at vent. Are you replaceing any parts? Must pump down to vac at least 30 Mins.
