beater72 Posted December 21, 2016 Share Posted December 21, 2016 What is everyone running for exhaust on their big block cars? X pipe or h pipe or true dual? ( on almost stock or mild cam engines) Quote Link to comment Share on other sites More sharing options...
72-CLASSIC_RIDE Posted December 21, 2016 Share Posted December 21, 2016 Big Block, "H" Pipe 2 3/4" dia, what I selected when replacing exhaust system on Mild Build 402 CI engine. Doug. Quote Link to comment Share on other sites More sharing options...
Montemedic Posted December 21, 2016 Share Posted December 21, 2016 Stock 454 LS-5, factory manifolds, Pypes complete stainless steel exhaust system, straight dual exhaust, 2 1/2 inch pipe, Street Pro mufflers and tailpipes in factory locations. Quote Link to comment Share on other sites More sharing options...
Sam (Bones) Posted December 21, 2016 Share Posted December 21, 2016 3 1/2" all the way back with Flowmasters I'd like to drop down to a 3" Quote Link to comment Share on other sites More sharing options...
JMCQ442 Posted December 22, 2016 Share Posted December 22, 2016 Flowmaster H pipe 2 1/2" stainless Quote Link to comment Share on other sites More sharing options...
monte70car Posted December 22, 2016 Share Posted December 22, 2016 Got 2.5" flowmaster two big blocks and a Jegs 2.5" DYI kit on another. One is an H pipe while the others are true dual exhaust. Quote Link to comment Share on other sites More sharing options...
502ci Posted December 22, 2016 Share Posted December 22, 2016 If you want that true dual exhaust sound(stereo sound) don't use a crossover pipe...although you will lose a little power with the size of exhaust you will probably run. Unless you run a 3 1/2" exhaust then it isn't really necessary and would be way overkill for what you are planning anyways. Quote Link to comment Share on other sites More sharing options...
Dans '70 Z20 Posted December 28, 2016 Share Posted December 28, 2016 I currently have a SS454 with likely 575-600hp. Running 3/4 Sanderson headers (wish I went with Original Doug's or American Racing Headers full length headers). Headers have 2 7/8" primaries into Torque Tech 3" system with X-pipe. Smaller the header primaries the more torque you get down low (big blocks already have plenty of torque down low), if you use too large an exhaust pipe diameter you can lose back pressure and power also. Best bet. Find out where you will be horsepower wise, the cam you are using (power band range), what gears you plan on running (higher the gear, higher the final RPM at track ... the more exhaust volume needs to be moved) etc and call Torque Tech or a header manufacturer to get the right combination for your set up. Horsepower can be gained or lost based on the set up you use. With a mild build and gears that are not real high (below 3:73) you are likely looking at big block Headers with the smaller standard primaries (big block headers usually offered in two size primary tubes) and a full 2.5" exhaust with X-Pipe. From memory, I believe they say you only need to go to 3" exhaust if your in the mid 500hp range. Hope this helps. Dan Quote Link to comment Share on other sites More sharing options...
502ci Posted December 28, 2016 Share Posted December 28, 2016 Sadly Torque Tech Exhaust is no longer. Quote Link to comment Share on other sites More sharing options...
dbreese Posted December 29, 2016 Share Posted December 29, 2016 Sadly Torque Tech Exhaust is no longer. Keith was great to work with. Glad I got my 3" with x-pipe when I did. Best fitting exhaust system I have ever owned. David 1 Quote Link to comment Share on other sites More sharing options...
Steve70Carlo Posted January 4, 2017 Share Posted January 4, 2017 .030 over 454. I am running Hooker Headers into 3" true dual pipes through Dynomax Mufflers, and 3" pipes out the back. I used to have flowmasters on it but I actually wanted to quiet the car down a bit. I do prefer the Dynomax. Quote Link to comment Share on other sites More sharing options...
