o_rod Posted April 14, 2017 Share Posted April 14, 2017 These 2 ground rings, cannot remember where they go other than on each side of the steering wheel. Can someone help? Quote Link to comment Share on other sites More sharing options...
Dito707 Posted April 14, 2017 Share Posted April 14, 2017 You can ground those to any convenient spot behind the dash, I believe the large wire is grounded inside the dash by the ashtray in my 70' Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 14, 2017 Share Posted April 14, 2017 On my 71 NO A/C Monte: One goes here: And there is one attached to the parking brake assembly: Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted April 14, 2017 Share Posted April 14, 2017 What year do you have, 1970? The grounds mounted a little different on the different years. One goes to the steel dash frame just to the left of the steering column if looking from the front of the dash. The other goes to the lower mounting screw on the left side of the wiper switch. You may have screwed the small bolt back into the hole in the steel dash frame after removing that ground. Look for that hole or a small bolt/ screw. You can see where it is mounted in my picture. You can not see the wiper switch in my picture, but you will be able to figure it out. This is a 1972 dash with idiot lights, but will be the same for a full gauge dash. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 17, 2017 Share Posted April 17, 2017 Sorry don't mean to Hijack but Im having same issue reinstalling dash. 71 no A/C. My dash has an odd ground wire that goes around the headlight switch and a wire connects to a Metal Ground Bracket that is mounted by the wiper switch and extends to the dash metal frame where it is screwed in (see picture). So does one ground go to cluster , one ground go to metal frame and one to the Emergency brake pedal? Or two wires to metal frame and one to cluster? I also have a long pink wire with a clip (See Pictures). I have no Idea what this is for. Thanks Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted April 17, 2017 Share Posted April 17, 2017 All of those black ground wires all are soldered together in the dash harness and then they branch of from there. That being said where you mount them is not that important as long as everything that needs a ground is grounded. You have the headlight switch and wiper switch grounded already, now the loose black wires all should be able to be grounded to the steel dash frame where you have the bracket grounded for the headlight/ wiper switch. The only year I have seen the cluster grounded was 1970, and not on that many of them. The is no consistency on how GM grounded these. I have seen many variations of where the grounds were fastened. If you hare having ground issues with the cluster attach one there it will not hurt a thing. If you have a very long black ground wire that will reach the E brake assembly put one there. You can put the last one where you mounted that grounding bracket. Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted April 17, 2017 Share Posted April 17, 2017 I THINK that pinkish red wire is used for A/C applications only. I am pretty sure that I have only seen that wire on 1971 models. Been a while since I have dealt with a 71. Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 17, 2017 Share Posted April 17, 2017 Not sure but I think I have a pink wire related to my power trunk opener. Lot's of pink wires! Good luck. Quote Link to comment Share on other sites More sharing options...
snomobeelr Posted April 18, 2017 Share Posted April 18, 2017 Thanks guys.. I am also trying to figure out the heater controls. I believe I am missing a cable. Anyone have pics of how they are run and connected? Quote Link to comment Share on other sites More sharing options...
stangeba Posted April 18, 2017 Share Posted April 18, 2017 This is all I have on my 71 No A/C. I hope it helps. Bruce Quote Link to comment Share on other sites More sharing options...
RealRed70 Posted April 18, 2017 Share Posted April 18, 2017 You should have three cables. Quote Link to comment Share on other sites More sharing options...
