monte70z20 Posted August 18, 2019 Share Posted August 18, 2019 Putting inner fenders back in my 70 today and I purchased the battery tray support bracket. There is no instructions with the piece I purchased and I was given an unclear explanation where this mounts to the inner fender. Can anybody describe to me where exactly this little metal bracket mounts/bolts to or perhaps if possible to post a picture of it mounted? Hopefully picture of the bracket I attached below comes through. Thanks. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 18, 2019 Share Posted August 18, 2019 Hi! The flat side withe the 2 nuts welded to it goes against the fenderwell. The short side goes to the bottom of the battery tray. Make sure you use a short bolt. Otherwise you risk the chance of putting a hole in the battery. I will try to get a pic. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted August 18, 2019 Share Posted August 18, 2019 Hope this helps rob Quote Link to comment Share on other sites More sharing options...
monte70z20 Posted August 18, 2019 Author Share Posted August 18, 2019 Awesome guys. Thanks for the great description and the picture. Helps a ton!!! Quote Link to comment Share on other sites More sharing options...
