slightly over stock 454 with performer intake!
Terbronco7
what size carb should I get (cfm) I have a Edelbrock 600 cfm new in box will this work or is it too small? Thanks Engine has a small crane cam but rest is mostly stock except for intake please help
what do you want from a carb. The 600 will work but if you plan to use it how you built then that carb wont work. i would guess a 780 or 800 would be minimum and you can probably go much higher.
I'll agree with Antoine, I think I read originals were rated 750cfm which might be a minimum of 650cfm in todays world. Since you seem to be adding performance I wouldn't go with the 600. It does bite not being able to use a NIB just sitting around
