Can anyone ID this rear end?
TommySS454
No Chevelle ever had a rear with the "RC" code.
Can you tell us any more? What year do you think it is?
Can we see more pics, including the cover?
The 0515 is a date code but it's meaning changed through the years.
All I can find is that its an Olds diff with 3:08's inside. Oldsmobile delta 88's or the Jetstar..as far as thew RC code goes. the 05 15K would think its the 15th of November but the 05 is weird...
Darren
Don't have a close up picture of the cover but I will attach a pic that you can zoom in to it. Looks like an ordinary 12 to me.  All I will say is I put this rear end in after the previous one wore the trailing arm bolt holes to a nice oval shape. It wasn't the factory unit either. But my dad owned a salvage yard so this was already pulled out. I walked over to a selection of 12 bolts and picked one that was maybe a dozen years ago. Thanks for the replies.
May sound stupid, but what if the guy on the line stamped it backwards? "CR" would be a 3.07 posi according to a couple of lists out there.
That could be Joe.
Tommy, while you're at it, measure how wide it is from axle flange face to axle flange face.
Here's some numbers:
Widths:
1964 - 1967: 60.5 inches
1968 - 1972: 61.25 inches
Casting numbers found to be the most prevalent in Chevelle 12-bolt rear ends:
1965 Chevelle 3859140N
1966 Chevelle 3875745N
1967 Chevelle 3894939NF
68-69 Chevelle 3917124NF
1969 Chevelle 3959038NF
70-72 Chevelle 3969278NF
OK, I'm gonna go with what Joe said, that the stamper got the letters swapped when he stamped it.
The "CR" code would be a 1968 rear with the 3:07 ratio and the casting number.
It should measure 61.21 inches.
