stupid me
willie
Hey guys, I stupidly left my ign key on for days. I go in to start it the other day after about 2 weeks and its dead as a doornail. I charged the batt up and started it up. Now I have a bad vibrating noise from the regulator. I changed the regulator out and now the AMP gauge is pointing down again. Anyone have any ideas?
Thatks
Hey Willie. There are threads on the amp gauge pointing down and how to "reset" it. Mostly on Chevelle sites.
Sounds like the regulators contacts "cooked" from the battery being on and going dead causing the vibrating noise.
Tom, I feel like 1 step forward and 2 back. lol     thx I will have to go back on there site and look, last time they said to take the needle off and reset it. I am not doing that. But I will go back and see what else they say.
Thanks
Sorry Willie, not quite sure. Something like removing the amp gauge lead at the regulator and touching it to the 9v. Read it on a Chevelle site.
Was going to try it on "barn find". Haven't gotten to that issue yet. Lol
Tom and Joe just a heads up. The AAA batt didn't work, however i then tried a 9V and it worked perfect.
Now i am asking you guys, how is the rad support grounds to the frame? By the fenders, or is there a ground strap?
Thanks Again
That's good to hear, at least it worked for you. As far as the core support ground, no straps that I'm aware of. The small neg. battery lead goes to the fender right there, possibly a path like you're thinking. Maybe Tom has more thoughts on it. The forward wire harness has a couple of spots that ground there if I remember correctly (I'm at work), but that may be for the front lights to work properly. I can check a schematic later if needed.
Glad the 9v worked Willie!  The rad support gets grounded through the body with the ground strap from the firewall to the frame.
You could always add another if you like. I always use the "trifecta" theory. Bigger ground cables, one from the body to the frame, second from the frame to engine and the third from the engine to the body. Bad grounds will always give you weird electrical Gremlins.
Like Tom says, I'll be adding grounds everywhere, but in my case there's going to be a lot of extra stuff, sensitive to grounding like fuel injection ECM, electronic transmission control, digital dash, etc.
Thanks guys. I have the trifecta on already, but because I don't have the nose on, I would think the rad support is not grounded yet. My problem was the reg went bad because I left the key on, but the headlights worked at that time. Now I can only get them to work if I ground the rad support.
Thanks for all the help guys!!!
