Steering Shaft Clearance
201fireman
Is shaft rubbing on one of the tubes?  What we have done is mark the spot where it rubs. Then take a 1" pipe or maybe 1 1/4" pipe and use the pipe to make a "dent" in the tube by hitting the pipe with a big hammer. This is a two person job. The pipe will make a cleaner look then beating the tube with a hammer. You will need the header off the engine. If you would like I might be able to get a pic.
  • 2 months later...
