Traveler Posted February 18, 2020 Share Posted February 18, 2020 anyone have experience with a small block and high rise manifolds and hood clearance I’m considering a victor junior and a holley thanks all j Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted February 18, 2020 Share Posted February 18, 2020 You should have no problem. If you are planning on using an air cleaner you will need a dropped base one. Quote Link to comment Share on other sites More sharing options...
Traveler Posted February 18, 2020 Author Share Posted February 18, 2020 thanks Quote Link to comment Share on other sites More sharing options...
knucklehead Posted March 20, 2021 Share Posted March 20, 2021 On 2/17/2020 at 10:32 PM, MC1of80 said: You should have no problem. If you are planning on using an air cleaner you will need a dropped base one. What is a dropped base air cleaner, were did you fine one? Thanks Quote Link to comment Share on other sites More sharing options...
1Bad454 Posted March 20, 2021 Share Posted March 20, 2021 Here's one. 14 in. Air Cleaner Dropped Base 5-1/8 in. Centered Opening Part Number: 555-50037 Quote Link to comment Share on other sites More sharing options...
Leghome Posted March 21, 2021 Share Posted March 21, 2021 that looks like the base on my 72 Quote Link to comment Share on other sites More sharing options...
Traveler Posted March 21, 2021 Author Share Posted March 21, 2021 On 3/19/2021 at 11:53 PM, knucklehead said: What is a dropped base air cleaner, were did you fine one? Thanks when I installed this base and a 3” filter I took a piece of modeling clay rolled it into a cylinder and stuck it on the top of the air cleaner and closed the hood slowly. Upon opening the hood I measured the clay to see its height (it had been compressed by the hood when closed) and had over 3” of clearance, hope this helps 1 Quote Link to comment Share on other sites More sharing options...
