New aluminum radiator different size inlet port
astrochimp
FINALLY getting rid of the original radiator to help with cooling on hot days and save 100 POUNDS in weight. The thermostat housing port is 1 5/16"  and the new aluminum radiator is 1 1/8" inlet port.
There's probably 20 ways to handle this but wondered what would be the best solution? I was thinking get a hose that has the diameter right between the two and make  it work with clamps.
What size is the bottom? I would call and complain. Maybe they will just send you the correct one for your application. The answer is always NO unless you ask.
