Grant MacPherson Posted May 11, 2020 Share Posted May 11, 2020 during inspection and cleaning I came across 2 holes at the bottom of the rear quarter panel below the quarter glass level with the frame. Difficult to see but you can feel them, about 1" x 1.5" ovol. Are they left open or should they be pluged. You can't see them from under the car. Didn't find them mentioned in any of the suppliers catalogs. Thanks Quote Link to comment Share on other sites More sharing options...
Rancid87 Posted May 12, 2020 Share Posted May 12, 2020 Are you talking about these holes in the rocker panel? Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted May 12, 2020 Author Share Posted May 12, 2020 size looks about right but I think the location is wrong. If I stick my arm down into the door jam vent opening (tight fit) at the bottom towards the inner panel is where I feel the holes. If I put a light on the inside of the frame some light shines through but you can't see the opening.? Quote Link to comment Share on other sites More sharing options...
Rancid87 Posted May 13, 2020 Share Posted May 13, 2020 Maybe these pics will give some perspective of where the hole is. You can see the first hole closest to the door jamb support. If it's not those holes than I'm not sure which ones you are referring to! Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted May 13, 2020 Share Posted May 13, 2020 Yes, those holes are supposed to be there and open. I believe they are for letting any water that may get by the outer window felts out of the car by going into the rocker panels and out. Instead of sitting there and/or going into the interior. Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted May 13, 2020 Author Share Posted May 13, 2020 Yes, that is them. Easy to see with the quarter off. Thanks Quote Link to comment Share on other sites More sharing options...
