monte70z20 Posted May 15, 2020 Share Posted May 15, 2020 I took my floor shifter out today and the screws mounting it to the Tunnel were two different sizes. 2 on the driver's side were approx an 1" long and the two on the passenger side look to be 1/2" long (see picture). I can't find sizes in the Service Manual and the assembly manual doesn't show a good picture of them. The short ones don't seem to fit well (the shifter was mounted over the carpet). Anybody tell me if this is correct? Also couldn't find them to buy on any of the usual sites but saw these for a Camaro/Firebird and wondered if they'd fit if I have to replace them. Quote Link to comment Share on other sites More sharing options...
monte70z20 Posted May 15, 2020 Author Share Posted May 15, 2020 Sorry, here is the website for the Camaro/FIrebird hardware: https://www.heartbeatcitycamaro.com/store/product/17854/68-69-Camaro-%26-Firebird-Automatic-Shifter-To-Floor-Tunnel-Mounting-Hardware-Kit/ Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted May 15, 2020 Share Posted May 15, 2020 Hey John. The shifters in our fleet all have the short style bolt bolting the shifter to the floor. Main thing is all the floor shifter cars we have, have the carpet under the console is cut out/ missing from the factory. The shifter is bolted directly to the floor. You can reuse the bolts you have. The only issue is if the long ones interfered with something like the driveshaft, which it obviously did not. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted May 15, 2020 Share Posted May 15, 2020 John, what you linked to on the Camaro site are rivnuts. You drill a hole, insert the nut then tighten down hard on them until they collapse and stay in place. I used stainless sidewalk bolts poked up from the bottom. They have a very wide very flat head. https://www.ebay.com/sch/i.html?_from=R40&_nkw=sidewalk+bolts&_sacat=0&_sop=15 Quote Link to comment Share on other sites More sharing options...
monte70z20 Posted May 15, 2020 Author Share Posted May 15, 2020 Thanks guys for your quick reply. This is very helpful. Paul: I am assuming you poked them through the bottom then used a nut inside the car to tighten them down. Is this correct? Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted May 15, 2020 Share Posted May 15, 2020 Yessir, that's correct. Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted May 15, 2020 Share Posted May 15, 2020 Sidewalk or “hurricane” bolts are normally used to hold down decking that people are gonna walk on. They have extremely flat heads with beveled edges that’s difficult for shoes to get caught on. Also, for commercial buildings, threaded anchors are placed in the concrete around entrances and sidewalk bolts are installed to keep the threads clean. The anchors allow things such as temporary banners or barriers to be bolted down without drilling new anchor points. Quote Link to comment Share on other sites More sharing options...
monte70z20 Posted May 16, 2020 Author Share Posted May 16, 2020 Makes sense...Thanks! Quote Link to comment Share on other sites More sharing options...
cascaranorick@yahoo.com Posted May 30, 2020 Share Posted May 30, 2020 they look like your trim bolts all over the front end,(fenders,inner wheel wells,etc) Quote Link to comment Share on other sites More sharing options...
