dcmoore2
brake drums hot
After driving a few miles, under normal conditions, i can get out and feel the rear drums and they are very hot to the touch. They were both doing it at first so i re-adjusted the shoes, thinking that i had adjusted too tight. Now the drivers side is the only one that gets really hot. I recently replaced the master cylinder, rear wheel cylinders and all the brake lines. I have loosened the parking brake cable also - thinking that may be the culprit but it was not. I have read that the master cylinder could have been a little different than what was on it and the rod could be too long - making the brakes drag? I also have read that the proportioning valve could also be plugged or is getting too hot from the header tube being about 1/2 inch away...i am going to try and adjust the brake pedal rod to make sure clearance is there. Then i'll tackle the proportioning valve with a heat shield or wrapping the header or moving it altogether. Anyone have this same issue?
Share this post
Drum brakes have an adjuster that operates when you hit the brakes while backing up. They're left/right specific. If you mixed them up, every time you step on the brakes, they'll adjust tighter.
When I used to do drum brakes, I pulled both drums but did one side completely before disassembling the other.
Share this post
Paul I do the same thing, one side at a time.  Not only do you not mix up the parts but it is also a reference to be able to look at one side  to compare the spring placement when you don't do drum brakes very often...
Share this post
The drums will get somewhat warm with normal use. Make sure they are adjusted properly, they don't need a lot of drag as some think. Make sure the wheel cylinders are working properly. The adjusters should be marked R&L under the caps that come off. Make sure you dont have a big difference in drum size. I believe 30 thousandths is the max variation side to side. Short shoe to the front always. Let us know how you make out.
Share this post
i adjusted almost all the way in this time. I now have cool drums but the brakes really need a lot of pressure to stop. I will now adjust out a little at a time until i feel that they are working properly, but with no heat from drag. i still think it could be the proportioning valve being gunked up or rusty inside.
Share this post
a good bleeding of the lines might be in order. I had an old car that would slowly apply the brakes as I drove higher in elevation. I actually had to stop and let some pressure out 1/2 way to my destination. No problem on the way down. A good pressure bleed with fresh fluid fixed it.
Share this post
