Vacuum lines to carburetor
sbarnette
I know this isn't going to help....when I pulled mine there was no vac port on the front (right side circle yours shows capped) The center port was capped as it looks like yours is. Where does the left circled line end up, that looks like a hard line not rubber vacuum. I only had 2 lines off the carb, one for the PVC and the other to the dizzy.
