Katman Posted August 2, 2020 Share Posted August 2, 2020 Can someone help me identify what this is and where it goes. I seem to recall it was used under the dash, drivers side. I may be wrong. Quote Link to comment Share on other sites More sharing options...
jft69z Posted August 2, 2020 Share Posted August 2, 2020 I think it's for the directional signal flasher. It mounts up above the steering column on the heavy metal bracket directly above the column. I don't have any good pics from my disassembly, sorry. It'll be somewhere above the brake light switch too. 1 Quote Link to comment Share on other sites More sharing options...
Paul Bell Posted August 2, 2020 Share Posted August 2, 2020 Joe is correct but I'm not sure what this brace is that it's screwed to. Quote Link to comment Share on other sites More sharing options...
Leghome Posted August 2, 2020 Share Posted August 2, 2020 Dimmer switch bracket? Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 2, 2020 Share Posted August 2, 2020 Dimmer switch is on the floor. No brackets. The flasher bracket/holder you have pictures mounts to the brake pedal main bracket. Quote Link to comment Share on other sites More sharing options...
jft69z Posted August 2, 2020 Share Posted August 2, 2020 Yep, Tom is right. It's the heavy bracket that's directly over the steering column. Also pokes thru the firewall to mount the power brake booster and is the mounting bracket for the brake /clutch pedal pivot, and the brake light switch. It's also sandwiched between the 2 steering column attachment nuts and the main dash structure. (the picture doesn't show the entire bracket where it keeps going to the other mounting holes). In the added picture, I think it would be the smaller of the 2 holes (circled in yellow)? My car doesn't need the bracket because the American Auto Wire harness mounts the flasher relay on the fuse block. Quote Link to comment Share on other sites More sharing options...
Katman Posted August 2, 2020 Author Share Posted August 2, 2020 Thanks again Monte family. I thought it might be there to secure the flasher from flopping around. Quote Link to comment Share on other sites More sharing options...
