Canuck Posted August 18, 2020 Share Posted August 18, 2020 My dipstick tube pulls out of the block when I pull the dipstick. I can’t see anything that’s supposed to hold it In the block. Should the end of the tube simply be flared a little more so it stays in? Quote Link to comment Share on other sites More sharing options...
Dtret Posted August 18, 2020 Share Posted August 18, 2020 The way I remember it is the bottom end is the smallest and it tapers up till it’s tight at the flared ring or it flares right below the ring. I have pushed them in and the use a small block of wood for the final tap tap to lock it in place. 1 Quote Link to comment Share on other sites More sharing options...
Leghome Posted August 18, 2020 Share Posted August 18, 2020 On one of my former autos I had that problem of the dipstick tube pulling out and I just tapped the end of it with a small hammer to elongate it and then reinstalled it. Worked great but I also cleaned everything thing around the block and tube and put a small dollop of gasket sealer to make sure it did not leak. 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 18, 2020 Share Posted August 18, 2020 I agree with what Leghome stated. You can also use a little silicone after you opened it up a little or just try the silicone. Just make sure you clean both areas well. Quote Link to comment Share on other sites More sharing options...
Canuck Posted August 19, 2020 Author Share Posted August 19, 2020 Thanks guys! 1 Quote Link to comment Share on other sites More sharing options...
SPLATT71MC Posted September 6, 2020 Share Posted September 6, 2020 Use a bit of this. https://www.amazon.com/Loctite-37424-Strength-Retainer-6-milliliter/dp/B0002KKTIG Quote Link to comment Share on other sites More sharing options...
