201fireman Posted August 20, 2020 Share Posted August 20, 2020 I swapped a TH350 for a TH400. I used the same shifter cable and things. When I put it in gear, the floor shift doesn't line up with the gears as you got through them. For example, when it is in drive, you look down and the shifter says it is in the neutral position. It goes through the gears ok, the spacing between the gears just seems tighter. Am I missing something? Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 20, 2020 Share Posted August 20, 2020 The th400 and th350 use different cable brackets on the transmission. Did you use the correct bracket? Quote Link to comment Share on other sites More sharing options...
Mike Brichta Posted August 20, 2020 Share Posted August 20, 2020 Also, there is an adjustment bolt and slot on the bottom, side of the horseshoe shifter handle. Quote Link to comment Share on other sites More sharing options...
wallaby Posted August 20, 2020 Share Posted August 20, 2020 You can fudge it, and use it as it is, but the neutral safety switch will be confused. You may find you can't start it in neutral. Get the right bracket and adjust it, and all should be good. I usually put the trans in neutral, and the shifter in neutral, and make the adjustment. If you get neutral right, it most likely will travel up to park ok, and then down to low ok;. Quote Link to comment Share on other sites More sharing options...
201fireman Posted August 21, 2020 Author Share Posted August 21, 2020 Gotcha, thanks guys. Yes I did buy the right bracket on the side of the trans. I believe my TH350 bracket was horizontal and this one is vertical or the other way around. I am betting the adjustment on the horseshoe handle might solve it. I wasn't aware of that. I am using the same cable from the shifter to the bracket, that's was I was hoping wasn't the problem with the TH400 sitting back a bit farther. I guess I look at the shifter adjustment. Thanks again for the help guys! Quote Link to comment Share on other sites More sharing options...
