sendo Posted September 19, 2020 Share Posted September 19, 2020 my rear bumper is pushed in on the driver side, I took off the bumper and can't tell what is bent how are you guys fixing this? Quote Link to comment Share on other sites More sharing options...
sendo Posted September 19, 2020 Author Share Posted September 19, 2020 On 11/26/2018 at 6:06 AM, MCfan said: Congratulations, Sendo! I bought my '70 SS the same way ... only from photos and telephone conversations with the seller. I jumped on it within an hour or two of it appearing on our site but, even so, I was second in line to a local buyer. I went ahead and made an offer and won by only $500. There may be a number of little things you'll want to correct/change, but that's the fun of acquiring a pre-owned classic - making it your own. You may even have a twinge of buyer's remorse when you actually see the car, but it sure looks like a reasonably solid survivor in the photos. I was really disappointed in how absolutely filthy (primarily dirt and road grime) my SS was when I picked it up. The engine compartment, interior and trunk had all been neglected but a lot of elbow grease and shop rags later that was resolved. I see your rear bumper needs to be realigned just like mine did. I went ahead and refurbished the rear bumper and brackets and may have a project photo journal on Photo Bucket if you're interested. Enjoy your new ride ... nothing like finally scratching the "SS itch"! 😄 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted September 20, 2020 Share Posted September 20, 2020 Mine was bent out just a little bit, I was suprised how easy it bent back after I loosened the bracket a little bit. Maybe a pry bar might bring it out what you need. 1 Quote Link to comment Share on other sites More sharing options...
MCfan Posted September 20, 2020 Share Posted September 20, 2020 Sendo, The rear bumper on my SS was not bent but the brackets needed realignment with the frame. I removed the bumper (as you also have done) and then removed the brackets so I could clean and re-paint them. I sprayed the back side of the bumper with Bumper Chrome by Plastikote and sprayed the brackets with Rustoleum semi-gloss black. I inspected the brackets for bends but found none. When I remounted the bumper to the frame, I aligned it the way I wanted and it bolted right up. At that time my rear bumper did not have bumper guards (I mounted a pair several years later) so maybe the bumper was pushed out of alignment when someone tried to push the Monte from the rear. I guessing you can remount your bumper in the correct position. You may need to have someone hold it in place while you tighten the bolts. Good luck. 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted September 20, 2020 Share Posted September 20, 2020 Like Steve mentioned above, I've adjusted minor misalignment's at the corners by pulling on it with the bumper attached. The '72 has a little different corner brace than the one you seem to have, so loosening the corner bolt a bit may help. On mine, I just pulled and it went where I wanted. 1 Quote Link to comment Share on other sites More sharing options...
