MC-71 Posted January 8, 2021 Share Posted January 8, 2021 I have been finding out that no one makes a replacement trunk floor for our Monte’s, only Chevelle’s. Need input on what brand is the best. AMD says they don’t offer one and the Chevelle is not a real replacement for the Monte. You would have to make it fit if you have the skills. I think I can make it right but I only wish the other vendors would be upfront on the fit. I can’t believe no one makes it for a 3 year model. Let me know how your install went. Quote Link to comment Share on other sites More sharing options...
714024SPEED Posted January 8, 2021 Share Posted January 8, 2021 I used the AMD trunk sections not the one piece floor and only had to modify the rear(cut about 3" off rear) to match up to the Monte floor 1 Quote Link to comment Share on other sites More sharing options...
Boots Posted January 8, 2021 Share Posted January 8, 2021 used a one piece...took lots of time and effort and an international trip to leos to get the piece i needed 1 Quote Link to comment Share on other sites More sharing options...
MC-71 Posted January 10, 2021 Author Share Posted January 10, 2021 So far this is what I’ve found out. AMD or Jeg’s don’t carry the 3 pc kit with the under rails. I don’t want a 1 pc. I will try Summit next. Quote Link to comment Share on other sites More sharing options...
LostnFound Posted January 30, 2021 Share Posted January 30, 2021 The one piece with braces is a great way to go. It only needs to be “modified” at the rear. You cut the rear of it off and seam it where it meets the flat shelf therefore using your original tail panel Quote Link to comment Share on other sites More sharing options...
MC-71 Posted February 6, 2021 Author Share Posted February 6, 2021 Was your body off? Can I get it in from underneath? I’m not planning on taking the body off and that’s why I want to use the 3 pc. Quote Link to comment Share on other sites More sharing options...
