RH72 30 Posted January 21 Share Posted January 21 Replacing the Gas Tank in my 70. Looking at the 2020 OPGI Catalogue Page 100. For the 70 Tank Kit, there are two choices, w/o vents and w/return. Any insight on these options? Existing tank attached. TY, Bob Quote Link to post Share on other sites
Mike Brichta 79 Posted January 21 Share Posted January 21 It looks like the one pictured has no vents and does have a return. Hope that help!! Mike Quote Link to post Share on other sites
RH72 30 Posted January 21 Author Share Posted January 21 Mike, yup, TY. I was hoping to gain an understanding of the difference between the original tank designs. Quote Link to post Share on other sites
Rob Peters 1,217 Posted January 21 Share Posted January 21 Did you find a Build Sheet on top of the old tank? rob Quote Link to post Share on other sites
cny first gen 71 440 Posted January 21 Share Posted January 21 What's wrong with that tank? Is it leaking somewhere or bottom damaged. I'd rather have an OEM tank than a replacement. Mine wasn't bad at all I cleaned it up and painted it looks like new. MC1of80 1 Quote Link to post Share on other sites
MC1of80 537 Posted January 21 Share Posted January 21 The tank itself has no vents or return lines. The gas tank sending unit does. I agree with cny first Gen 71. If the original is usable, by all means use it. My 70 has an aftermarket tank in it. At the time the only tank made for the Monte was the 71-72 tank. It has a vent/return line nipple at both corners of the tank. I used rubber caps to block the vents. Needless to say, every year they have to be changed due to them rotting and leaking. Nothing rubber is made like it used to be. Quote Link to post Share on other sites
RH72 30 Posted January 21 Author Share Posted January 21 2 hours ago, cny first gen 71 said: What's wrong with that tank? Is it leaking somewhere or bottom damaged. I'd rather have an OEM tank than a replacement. Mine wasn't bad at all I cleaned it up and painted it looks like new. Tank has a hole in it, or I would keep it in the car. MC1of80 1 Quote Link to post Share on other sites
RH72 30 Posted January 21 Author Share Posted January 21 1 hour ago, MC1of80 said: The tank itself has no vents or return lines. The gas tank sending unit does. I agree with cny first Gen 71. If the original is usable, by all means use it. My 70 has an aftermarket tank in it. At the time the only tank made for the Monte was the 71-72 tank. It has a vent/return line nipple at both corners of the tank. I used rubber caps to block the vents. Needless to say, every year they have to be changed due to them rotting and leaking. Nothing rubber is made like it used to be. Tank has a hole in it, or I would keep it in the car. Quote Link to post Share on other sites
cny first gen 71 440 Posted January 21 Share Posted January 21 2 hours ago, RH72 said: Tank has a hole in it, or I would keep it in the car. Oh ok bummer I guess you're right time for a new one. Quote Link to post Share on other sites
RH72 30 Posted January 21 Author Share Posted January 21 Steve, looked at patching it, but a new one is the right way to go. cny first gen 71 1 Quote Link to post Share on other sites
