Dtret Posted February 5, 2021 Share Posted February 5, 2021 Based on the pic is 1100843 the correct alt. My car had ac power windows and locks. Also zinc or black fan. Black or zinc pulle. Thanks Dennis Quote Link to comment Share on other sites More sharing options...
jft69z Posted February 5, 2021 Share Posted February 5, 2021 Looks correct, unless your build sheet says K85, which appears to be the RPO code for the 63 amp alternator. The GM heritage center docs show that part number too, for those engines, thought it says 37 amps for the Chevelle, etc part number. Scroll down to the 'AMA Specification forms' section, lot of good info and part numbers there. https://www.gmheritagecenter.com/docs/gm-heritage-archive/vehicle-information-kits/Monte-Carlo/1971-Chevrolet-Monte-Carlo.pdf Quote Link to comment Share on other sites More sharing options...
Dtret Posted February 5, 2021 Author Share Posted February 5, 2021 I printed that out awhile ago but it left me confused on the alternator. 1100843 is a 61 amp. I found one date code correct and remanufactured so I bought it. Now I’m not sure it’s correct. The one I took off was dated 69 and 37 amp. More research. Thanks Joe Quote Link to comment Share on other sites More sharing options...
Jerry Skidmore Posted February 5, 2021 Share Posted February 5, 2021 1100843 would be correct if you don’t have the K85 option. I believe the fan and pulley should both be silver zinc. Quote Link to comment Share on other sites More sharing options...
Dtret Posted February 6, 2021 Author Share Posted February 6, 2021 19 minutes ago, Jerry Skidmore said: 1100843 would be correct if you don’t have the K85 option. I believe the fan and pulley should both be silver zinc. No k85 option on build sheet. That’s what I was thinking on the fan and pulley but you look at internet pics and there all over the place. Joe sent me a list of colors for restoration,dahm good list,but it didn’t have the pulley on it and I’ve seen them cadmium plated as well. Thanks Quote Link to comment Share on other sites More sharing options...
Leghome Posted February 6, 2021 Share Posted February 6, 2021 When I assembled the GM alternators back in the 70's the pulleys were cadmium plated. When I worked in the reman area they were goldish color in later years Quote Link to comment Share on other sites More sharing options...
