Changing from 2.73 to 3.42 gears, necessary different speedo gears
ejw71
In changing rear gear ratios (to 3.42) the 350TH trans output shaft drive gear and the speedometer driven gear also required a change to have speedometer read correctly. These gears are color coded for teeth count. So, what color gear/teeth count do I need? Thanks, Ed Wieder, ejw71
Just a thought and maybe this has gone into the calculation  along with your gear ratio change are you also taking into consideration oversized tires?
