msapia Posted December 13, 2021 Share Posted December 13, 2021 Can anyone tell me why Summit and American Racing both say these wheels won't fit? I'm wanting to run 255/60R15 all around. From what I've been reading here and other places, they should fit just fine. https://www.summitracing.com/parts/are-50158034500 Quote Link to comment Share on other sites More sharing options...
msapia Posted December 13, 2021 Author Share Posted December 13, 2021 Ok...so I called summit. He said these wheels will fit. Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted December 14, 2021 Share Posted December 14, 2021 With 8 inch wheels and 255-60s on front just check clearance on tight turns to see about rubbing just to be sure. Quote Link to comment Share on other sites More sharing options...
MCfan Posted December 14, 2021 Share Posted December 14, 2021 Mike, I used the wheel offset calculator at tiresize.com to compare your wheel/tire combo to mine and verified that it should fit fine on both front and rear. In fact, you will have slightly more inboard clearance on the front (to avoid frame rubbing) than my setup which is 255/60-15 on 15x7 rims with 4.5" BS. On the rear, your outboard side wall has only .07" less clearance from the wheel well lip than my 275/60-15 on 15x8 rims with 5.0" BS and I currently have about .75" of side wall clearance. However, if you ever decide to mount 275/60s on the rear, the 4.5" BS on those 8" wide rims could get you dangerously close to the wheel well lip (unless you also decide to trim it). Great looking wheels, BTW! Quote Link to comment Share on other sites More sharing options...
Canuck Posted December 22, 2021 Share Posted December 22, 2021 255/60/15 on all four stock 15x7 rally wheels. A lot of clearance and zero rubbing issues. If you have rims with improper offset/backspacing then you could run into problems. I have 15x8 Corvette rallys on my other Monte and the 245/60/15 tires rub on the quarter panel. 1 Quote Link to comment Share on other sites More sharing options...
