D N Monte Posted December 28, 2021 Share Posted December 28, 2021 Hi everyone I'm trying to remove my original radio from the dash of my 1972 Monte Carlo can you help? Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted December 28, 2021 Share Posted December 28, 2021 Take the knobs off, remove the nuts and washers on the shafts. Unbolt the bracket on the back of the radio, remove the wire connector and antenna wire and remove from dash. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted December 28, 2021 Share Posted December 28, 2021 Like Tom said and it's tight back there.....good luck Quote Link to comment Share on other sites More sharing options...
D N Monte Posted December 28, 2021 Author Share Posted December 28, 2021 25 minutes ago, MC1of80 said: Take the knobs off, remove the nuts and washers on the shafts. Unbolt the bracket on the back of the radio, remove the wire connector and antenna wire and remove from Thanks! Got it. Quote Link to comment Share on other sites More sharing options...
Dtret Posted December 28, 2021 Share Posted December 28, 2021 If it’s totally original you may have the slotted small nuts. It requires a special tool they say. But a needle nose should get it done. 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted December 28, 2021 Share Posted December 28, 2021 That’s what it looks like if you really need it. Quote Link to comment Share on other sites More sharing options...
454 Monte Posted September 3, 2022 Share Posted September 3, 2022 I removed the front knobs and bolts. However, there is a bolt to the radio on the passenger side and then a bracket that goes up on the driver side into the dash. Which is the bracket/bolt to take out to pull it back? Quote Link to comment Share on other sites More sharing options...
