MrDavie Posted January 25, 2022 Share Posted January 25, 2022 Finally got my Monte in, can’t even find out how to pop the hood?? Also, i see screws on the dash holding it together, is this one piece I can order and have it installed correctly? Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted January 26, 2022 Share Posted January 26, 2022 Hello, welcome! The way to open the hood is above the front license plate. You should see a black tab. Pull towards you till the hood opens. The screw you show is not factory installed. If you remove it, besides the side of the dash pad popping out, most likely. There will be a hole in the dashboard itself. I would find a brown paint that closely matches the dash and paint the screw head untill you decide what route you may take. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 26, 2022 Share Posted January 26, 2022 Richard, Glad to hear you got your Monte. The hood release should be in the opening in the middle of the front bumper where the license plate area. It should be just a piece of metal that has a slight hook in it. It does not quite extend past the bumper thus the top of the bumper sort of hides it. Regarding the dash. Neither that screw or whatever the other thing is should be there. The dash pad should be held down by screws that go straight up into it. Unfortunately the burlwood is not reproduced. You may be able to patch it but I think it will always be noticed. You may be able to find a used one either here through the members or on ebay. rob Quote Link to comment Share on other sites More sharing options...
MrDavie Posted January 26, 2022 Author Share Posted January 26, 2022 Found the lever but the top isn’t going past here Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted January 26, 2022 Share Posted January 26, 2022 Safety latch, pull the lever more and lift the hood at the same time. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 26, 2022 Share Posted January 26, 2022 20 minutes ago, MC1of80 said: Safety latch, pull the lever more and lift the hood at the same time. Tom is correct, the same lever is used for full opening. It can sometimes be a challenge. You have to contort yourself enough to do both pulling the release and lifting the hood at the same time but it does work. Maybe we should have people send pictures of themselves and the positions they have to get into to do this. rob 1 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 26, 2022 Share Posted January 26, 2022 NO. I have met some of the group. I know that I don’t want to see that kind of contortion. Lol. 1 6 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 26, 2022 Share Posted January 26, 2022 Mine is much easier since I put the extra spring in it and closes easier, that's probably because I adjusted it correctly. Quote Link to comment Share on other sites More sharing options...
Canuck Posted January 26, 2022 Share Posted January 26, 2022 Welcome! You have some good answers here so no need for me to repeat them. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted January 26, 2022 Share Posted January 26, 2022 18 hours ago, Rob Peters said: Tom is correct, the same lever is used for full opening. It can sometimes be a challenge. You have to contort yourself enough to do both pulling the release and lifting the hood at the same time but it does work. Maybe we should have people send pictures of themselves and the positions they have to get into to do this. rob Fat fingers can be an issue too.... Those greasy sausages don't always grip the bottom edge. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted January 26, 2022 Share Posted January 26, 2022 18 hours ago, Rob Peters said: Richard, Glad to hear you got your Monte. The hood release should be in the opening in the middle of the front bumper where the license plate area. It should be just a piece of metal that has a slight hook in it. It does not quite extend past the bumper thus the top of the bumper sort of hides it. Regarding the dash. Neither that screw or whatever the other thing is should be there. The dash pad should be held down by screws that go straight up into it. Unfortunately the burlwood is not reproduced. You may be able to patch it but I think it will always be noticed. You may be able to find a used one either here through the members or on ebay. rob Check out "Mega Parts Post"..... Jared's got tons of stuff, and he's probably not that far from you. Quote Link to comment Share on other sites More sharing options...
71SSclone Posted January 29, 2022 Share Posted January 29, 2022 My hood is harder than most to open, When I pull the latch, it doesn't even pop up to get my fingers under it. I have to pry it open between the hood and the grill, then pull the latch more to get it open. One more thing to take care of when the body work gets done Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 29, 2022 Share Posted January 29, 2022 34 minutes ago, 71SSclone said: My hood is harder than most to open, When I pull the latch, it doesn't even pop up to get my fingers under it. I have to pry it open between the hood and the grill, then pull the latch more to get it open. One more thing to take care of when the body work gets done That's a fairly easy fix, I just did it on my car. I put an extra spring inside the other spring on the latch. It's a little difficult to see it but it's there and I also included the spring number, it's the one that's missing off the board. 3 Quote Link to comment Share on other sites More sharing options...
1970mcss Posted January 29, 2022 Share Posted January 29, 2022 I bought the spring but I can't get the latch apart. Not sure if I need heat it up Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 29, 2022 Share Posted January 29, 2022 20 minutes ago, 1970mcss said: I bought the spring but I can't get the latch apart. Not sure if I need heat it up Mine came right apart, try spraying with penatrating oil. Be careful with heat it could weaken the outer spring or replace it. Remember there is a jam nut at the top that's a little difficult to get a wrench on but doable. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted January 29, 2022 Share Posted January 29, 2022 I soaked the bolt a ton, I got the nut but I'll try it again over weekend, thanks Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted January 29, 2022 Share Posted January 29, 2022 47 minutes ago, 1970mcss said: I soaked the bolt a ton, I got the nut but I'll try it again over weekend, thanks There's a nut on the top also you may have to put a wrench on the screwdriver or try and grab the cone part with vice grips to break it loose. Quote Link to comment Share on other sites More sharing options...
71SSclone Posted January 30, 2022 Share Posted January 30, 2022 Thanks for posting, Steve. I'll have to try the "extra spring" idea 1 Quote Link to comment Share on other sites More sharing options...
Bad Wolf racing Posted February 11, 2022 Share Posted February 11, 2022 On 1/28/2022 at 7:59 PM, 71SSclone said: My hood is harder than most to open, When I pull the latch, it doesn't even pop up to get my fingers under it. I have to pry it open between the hood and the grill, then pull the latch more to get it open. One more thing to take care of when the body work gets done Probably the 50 year old spring has just worn out and weakened. I would try just replacing the spring first. 2 Quote Link to comment Share on other sites More sharing options...
1970mcss Posted February 11, 2022 Share Posted February 11, 2022 I got the helper spring installed. Works like a charm. They do sell the spring at Menards for anyone that's looking 1 Quote Link to comment Share on other sites More sharing options...
