Help identifying vacuum component
Hammer97321
As I am dismantling the engine on a 1970 Monte Carlo I ran across this device. The 2 vacuum lines were both plugged into different ports on the carburetor. One on the side and the other on the rear. What is it used for?
Every I can find tells me I do not need to hook it up and transmission told me he was just going to pull the transmission switch since he said they all eventually leak. If I pull the solenoid do I just run a vacuum line between the two carb ports and call it good.
