Crom Cruach Posted April 4, 2022 Share Posted April 4, 2022 I loosened this nut to adjust the advance as I checked the timing. I’m now wondering if it’s the correct nut because the dist didn’t budge when this nut was loose enough for the plate underneath to move freely. Is the plate underneath broken or am I at the wrong nut? Quote Link to comment Share on other sites More sharing options...
1970mcss Posted April 4, 2022 Share Posted April 4, 2022 It looks to be the distributer hold down bolt. The clamp sits on the shaft when you tighten it. The distributor would turn?? 1 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted April 4, 2022 Share Posted April 4, 2022 May just be stuck from not moving in a long time, give it a slight tap on vacuum advance with a rubber hammer see if it moves. Be very careful though as to not damage anything. 4 Quote Link to comment Share on other sites More sharing options...
420ponies Posted April 4, 2022 Share Posted April 4, 2022 That is the correct bolt to adjust distributor. May have to tap to get it to move. There is a gasket under it, gets sticky from that and also if oil has not been changed in a long while.Did you drain oil,new filter,1 quart transmission fluid, 4 quarts 30 weight, run engine to temperature for20 minutes ( no driving). Then Drain that oil, change filter, add your good oil, (I run Valvoline VR1 ) high zinc content. That trans fluid will clean any sludge in engine. No more the 20 minutes at temperature. I let it drain overnight. Should be good to go. 3 Quote Link to comment Share on other sites More sharing options...
Crom Cruach Posted April 4, 2022 Author Share Posted April 4, 2022 Maybe I don’t need to move it. I got 4° advance at cold idle, and 8° warm idle. I don’t know rpm but when I revved a little it went past 12°. Manual says: Centrifugal advance 18°@4200rpm 8° ignition timing at idle BTDC engine sounds good after I fixed a vacuum leak 5 Quote Link to comment Share on other sites More sharing options...
