kpcsgasp Posted April 24, 2022 Share Posted April 24, 2022 Still learning but today it won't crank. battery is new with 12.5 volts. ran fine yesterday. Trying to figure where to look next. Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 24, 2022 Share Posted April 24, 2022 What is it doing? Is the engine turning when you turn the key ? Does it do anything when you turn the key? If you just pull the light switch do the headlights come on? If it doesn’t do anything when you turn the key check your connection at the battery. 5 Quote Link to comment Share on other sites More sharing options...
71MonteCarloMD Posted May 9, 2022 Share Posted May 9, 2022 In addition to Dennis questions, I faced same situation on my 71 and found that the purple wire to the starter was very brittle. Suggest to check that as well. Quote Link to comment Share on other sites More sharing options...
