kpcsgasp Posted April 24, 2022 Share Posted April 24, 2022 Still learning but today it won't crank. battery is new with 12.5 volts. ran fine yesterday. Trying to figure where to look next. Quote Link to comment Share on other sites More sharing options...
DragCat Posted April 25, 2022 Share Posted April 25, 2022 Kevin, what do you mean won't crank, no starter, engine turns over but won't fire up ? 1 Quote Link to comment Share on other sites More sharing options...
cbolt Posted April 25, 2022 Share Posted April 25, 2022 Step one, tap the starter with a hammer lightly, and try again. Quote Link to comment Share on other sites More sharing options...
EVC Posted April 25, 2022 Share Posted April 25, 2022 What type of ignition are you using ? HEI / MSD, etc / Stock ? Quote Link to comment Share on other sites More sharing options...
DragCat Posted April 25, 2022 Share Posted April 25, 2022 Hey, he's got 2 threads going 1 Quote Link to comment Share on other sites More sharing options...
kpcsgasp Posted April 25, 2022 Author Share Posted April 25, 2022 engine not turning at all. started up and ran fine day before. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 25, 2022 Share Posted April 25, 2022 Like others have asked, power to the lights? Clicking sound? Any power to the car at all? Quote Link to comment Share on other sites More sharing options...
Lou Posted April 25, 2022 Share Posted April 25, 2022 When you turn the key, any sound at all, like a click? Or a metal to metal sound? Or nothing? Quote Link to comment Share on other sites More sharing options...
EVC Posted April 25, 2022 Share Posted April 25, 2022 Broken wire… Quote Link to comment Share on other sites More sharing options...
kpcsgasp Posted April 26, 2022 Author Share Posted April 26, 2022 no sound whatsoever. All lights working fine. no solenoid clicking. Battery at full charge. Quote Link to comment Share on other sites More sharing options...
kpcsgasp Posted April 26, 2022 Author Share Posted April 26, 2022 8 hours ago, Lou said: When you turn the key, any sound at all, like a click? Or a metal to metal sound? Or nothing? no sound whatsoever. All lights working fine. no solenoid clicking. Battery at full charge. Quote Link to comment Share on other sites More sharing options...
Lou Posted April 26, 2022 Share Posted April 26, 2022 Sounds like no power to solenoid. Check ignition fuse? Try giving the starter a couple whacks with a persuasion tool. If that doesn't work jump across the solenoid. If the starter comes to life check your ignition switch. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 26, 2022 Share Posted April 26, 2022 Maybe the Neutral Safety Switch is bad or out of adjustment. With the key turned to the start position try moving the gear shifter back & forth a little bit from the park position and then also from the Neutral position. rob 1 Quote Link to comment Share on other sites More sharing options...
EVC Posted April 26, 2022 Share Posted April 26, 2022 I had a similar problem when I changed over to an ignition system which required me to wire to 12 volts. It blew the inline fuse we had put in … Check the fuse panel and see if an inline fuse has been added for the Ignition … Ed C Quote Link to comment Share on other sites More sharing options...
kpcsgasp Posted April 26, 2022 Author Share Posted April 26, 2022 Thanks for all the suggestions. fortunately, the problem was the park interlock switch. I ran it through the gears a couple of times and it started right up. Again thanks for all the suggestions. 1 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 26, 2022 Share Posted April 26, 2022 Kevin, I think what you are referring to is the neutral safety switch. To the best. Of my knowledge our cars did not have a park interlock. A park interlock is used to keep the shifter from moving if the brake is not depressed and that safety didn't come out until much later. rob 3 Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 26, 2022 Share Posted April 26, 2022 The 'park interlock' is mechanical on these cars, using the back drive linkage to the transmission and steering column sleeve. The mechanical parts of it in the column also stop the steering wheel from turning when it's locked. The NSS would be the thing stopping you from starting it though as Tom and Rob mentioned. 1 Quote Link to comment Share on other sites More sharing options...
kpcsgasp Posted April 26, 2022 Author Share Posted April 26, 2022 I'm not always spot on with my descriptions but Rob you were spot on. thanks 1 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 26, 2022 Share Posted April 26, 2022 32 minutes ago, kpcsgasp said: I'm not always spot on with my descriptions but Rob you were spot on. thanks Any day you can learn something new is a successful day. I have seen the NSS cause problems before. Glad to assist. Even a blind squirrel finds a nut. rob 3 Quote Link to comment Share on other sites More sharing options...
DragCat Posted April 27, 2022 Share Posted April 27, 2022 11 hours ago, kpcsgasp said: I'm not always spot on with my descriptions but Rob you were spot on. thanks Glad you got it running Kevin. Like Rob said, when ya learn something new its a good day 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 27, 2022 Share Posted April 27, 2022 18 hours ago, kpcsgasp said: I'm not always spot on with my descriptions but Rob you were spot on. thanks It's an "acquired" terminology...... LOL !!! Quote Link to comment Share on other sites More sharing options...
Lou Posted April 27, 2022 Share Posted April 27, 2022 23 hours ago, kpcsgasp said: Thanks for all the suggestions. fortunately, the problem was the park interlock switch. I ran it through the gears a couple of times and it started right up. Again thanks for all the suggestions. Sounds like a good excuse to put a 5-speed in. All I know about automatics is the fluid level. I'll be learning more about them soon enough. Quote Link to comment Share on other sites More sharing options...
