shane87 Posted April 28, 2022 Share Posted April 28, 2022 My 70 has had a repaint in its past and they removed the rocker moldings. They filled the holes in the rocker for the mounting clips. Curious if anyone knows what size holes need to be drilled and how many per side. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted April 28, 2022 Share Posted April 28, 2022 I am sure someone will respond to help you. I can't imagine why they would have filled them without asking you first. rob Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 28, 2022 Share Posted April 28, 2022 Between the fender, the rocker and the quarter panel I want to say like 12. The one closest to the rear wheel has a rubber grommet in it for the only screw. Don’t hold me to that though. The clips you WANT to get are the AU-VE-CO 8400. Let others chime in first to check my info. This is all off memory. I’m not sure on the hole size. Quote Link to comment Share on other sites More sharing options...
Dtret Posted April 28, 2022 Share Posted April 28, 2022 3 minutes ago, Rob Peters said: I am sure someone will respond to help you. I can't imagine why they would have filled them without asking you first. rob Let’s hope it was done before he got the car. If it wasn’t, my first thought would be what else did they hide. Quote Link to comment Share on other sites More sharing options...
