rsorg Posted June 11, 2022 Share Posted June 11, 2022 hi, looking for the correct color and style tube that goes from manifold to the air cleaner ,thanks roger Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted June 11, 2022 Share Posted June 11, 2022 The one on mine was a metal tube, not sure of I still have it laying around somewhere. Quote Link to comment Share on other sites More sharing options...
DragCat Posted June 11, 2022 Share Posted June 11, 2022 Are you talking about the "paper" black tube ? Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted June 11, 2022 Share Posted June 11, 2022 It depends on the engine size. My 70 350 2brl is a metal black tube painted in semi-gloss same as the air cleaner. 2 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted June 11, 2022 Share Posted June 11, 2022 Yes I believe the small block and big block are different 1 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted June 11, 2022 Share Posted June 11, 2022 2 hours ago, cny first gen 71 said: Yes I believe the small block and big block are different Yes they are. I think the Big Block is a flexible type tube and the Small Block is a metal tube rob 1 Quote Link to comment Share on other sites More sharing options...
rsorg Posted June 11, 2022 Author Share Posted June 11, 2022 yes i have a 454 factory big block, and it is black paper type .and i would like to replace it with a new correct style one ,does any one know where i can get one thanks, roger Quote Link to comment Share on other sites More sharing options...
rsorg Posted June 11, 2022 Author Share Posted June 11, 2022 mark ,is your car a 70 or 71 my 72 does not have any stickers on the air cleaner ,i think that was for insurance reasons back then,roger Quote Link to comment Share on other sites More sharing options...
Glen Posted June 12, 2022 Share Posted June 12, 2022 9 hours ago, Rob Peters said: Yes they are. I think the Big Block is a flexible type tube and the Small Block is a metal tube rob Sounds right from what I’ve seen and read regarding the big blocks having the flexible tubing. What I recently learned is that our Montes use just a clamp to hold the tubing on the snorkel, whereas Chevelles have a 90 degree plastic elbow between the tubing and snorkel… 1 Quote Link to comment Share on other sites More sharing options...
Glen Posted June 12, 2022 Share Posted June 12, 2022 Hell, upon looking at the diagram again it says that “ALL EXCEPT MONTE CARLO” use the plastic elbow 🤷🏼♂️ 1 Quote Link to comment Share on other sites More sharing options...
DragCat Posted June 12, 2022 Share Posted June 12, 2022 13 hours ago, rsorg said: mark ,is your car a 70 or 71 my 72 does not have any stickers on the air cleaner ,i think that was for insurance reasons back then,roger Mine's a 70, and I think the decal is wrong (its reproduction) Back when the PO did the car some "correct" items weren't available aftermarket ( like the clear turn signal bumper lenses) . Quote Link to comment Share on other sites More sharing options...
DragCat Posted June 12, 2022 Share Posted June 12, 2022 13 hours ago, rsorg said: yes i have a 454 factory big block, and it is black paper type .and i would like to replace it with a new correct style one ,does any one know where i can get one thanks, roger I did a quick search at TPP and didn't see it listed, although I don't know the correct part name in the bowtie world. For my blue oval car its called "SNORKEL - AIR CLEANER - PRE-HEATER HOSE " Quote Link to comment Share on other sites More sharing options...
Scott S. Posted June 13, 2022 Share Posted June 13, 2022 I believe it's called a "heat riser tube".... Small blocks are bent pipe, big blocks use dryer vent piping. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted June 13, 2022 Share Posted June 13, 2022 11 minutes ago, Scott S. said: I believe it's called a "heat riser tube".... Small blocks are bent pipe, big blocks use dryer vent piping. OPGI has the small block one.... Metal tube. Quote Link to comment Share on other sites More sharing options...
Glen Posted June 13, 2022 Share Posted June 13, 2022 18 hours ago, DragCat said: Mine's a 70, and I think the decal is wrong (its reproduction) Back when the PO did the car some "correct" items weren't available aftermarket ( like the clear turn signal bumper lenses) . Yes it is wrong. The PO stole 10 ponies from you 🤣😂. If you decide to order the correct “Turbo Jet 360 HP” decal, get it from somewhere other than OPGI. When I purchased the correct air cleaner for my 70, decals weren’t included so I added both to an order from OPGI. Put them on and didn’t notice until a short time later that the gold border that is also supposed to separate the “Turbo Jet” and “360” is missing. Didn’t matter anyway… The air cleaner wouldn’t fit with the aftermarket carb that is on the car presently. So that air cleaner will be salted away until the car is returned to her former/original glory at some point after I retire. Quote Link to comment Share on other sites More sharing options...
DragCat Posted June 13, 2022 Share Posted June 13, 2022 5 hours ago, Glen said: Yes it is wrong. The PO stole 10 ponies from you 🤣😂. If you decide to order the correct “Turbo Jet 360 HP” decal, get it from somewhere other than OPGI. When I purchased the correct air cleaner for my 70, decals weren’t included so I added both to an order from OPGI. Put them on and didn’t notice until a short time later that the gold border that is also supposed to separate the “Turbo Jet” and “360” is missing. Didn’t matter anyway… The air cleaner wouldn’t fit with the aftermarket carb that is on the car presently. So that air cleaner will be salted away until the car is returned to her former/original glory at some point after I retire. Yea mines sitting in a box somewhere on a shelf. Like you wouldn't fit the carb after the engine swap. Luckily the PO had swapped out the ole el camino front bumper turn signals when OPGI/Someone had the correct lenses. Quote Link to comment Share on other sites More sharing options...
Dtret Posted June 13, 2022 Share Posted June 13, 2022 O by the way. Black. Quote Link to comment Share on other sites More sharing options...
Windjamer14 Posted January 22, 2023 Share Posted January 22, 2023 Very hard to find ONE FOR THE 454 ? THE COMPLETE SET UP. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted January 22, 2023 Share Posted January 22, 2023 Almost impossible, if you find 2 let me know Quote Link to comment Share on other sites More sharing options...
