Mikes72 Posted June 13, 2022 Share Posted June 13, 2022 Hi guys. I need some info on the rear console light bulb. Last one I put in melted the plastic, so were to get one and what would the volts be ? Quote Link to comment Share on other sites More sharing options...
Searsman Posted June 13, 2022 Share Posted June 13, 2022 Hi Mike, I have a doctors appt this morning so I can’t look it up till later.. but I will tell you it is a single filament 12 volt low wattage bulb.. same as on the console gear indicator underneath the horseshoe lever.. w bulb glass about the size of a dime.. that’s what is in mine.. but actually, all incandescent bulbs release heat.. so should be careful how long the dome and rear console light is on ... Quote Link to comment Share on other sites More sharing options...
jft69z Posted June 13, 2022 Share Posted June 13, 2022 If you're talking about the lamp in the very back of the console, it's a 212-1 according to the owner's manual. Rated at 6 candle power. Looks like the dome light, but that one is 211-1, rated at 12 CP. It's possible you may have put a dome rated lamp in there before and melted the plastic lens. Any auto parts store or online source should have what you're looking for. (A quick search shows 212-2 available, looks like the same specs) 1 Quote Link to comment Share on other sites More sharing options...
Leghome Posted June 13, 2022 Share Posted June 13, 2022 go with am LED no heat to speak of 1 Quote Link to comment Share on other sites More sharing options...
