Rear concil light
Mikes72
Hi Mike, I have a doctors appt this morning so I can’t look it up till later.. but I will tell you it is a single filament 12 volt low wattage  bulb.. same as on the console gear indicator underneath the horseshoe lever.. w bulb glass about the size of a dime.. that’s what is in mine.. but actually, all incandescent bulbs release heat.. so should be careful how long the dome and rear console light is on ...
If you're talking about the lamp in the very back of the console, it's a 212-1 according to the owner's manual. Rated at 6 candle power.
Looks like the dome light, but that one is 211-1, rated at 12  CP. It's possible you may have put a dome rated lamp in there before and melted the plastic lens.
Any auto parts store or online source should have what you're looking for. (A quick search shows 212-2 available, looks like the same specs)
