Energizerlehman61 Posted July 28, 2022 Share Posted July 28, 2022 Does anyone know if 2" drop spindles affect what tube A arms, you use? Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted July 28, 2022 Share Posted July 28, 2022 Only if the drop spindles are also tall. Which spindles are you looking at? Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 Don't know brand, opgi kit. Four wheel disk, wilwood calipers and master cylinder. I'm wanting tube A arms and coilovers. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted July 28, 2022 Share Posted July 28, 2022 What's the part number on the kit? If the spindles came with the kit they're most likely stock height, so the control arm can remain stock. Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 2" drop Quote Link to comment Share on other sites More sharing options...
Leghome Posted July 28, 2022 Share Posted July 28, 2022 I am almost willing to bet there are places out there to get that kit cheaper than OPGI. I have bought some stuff cheaper than OPGI at Summit or JEGS Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 It seemed like a good price, actually comes from right stuff. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted July 28, 2022 Share Posted July 28, 2022 I would personally go for an 11" booster for better braking. https://www.opgi.com/brake-systems/disc-brakes/performance-series-disc-brake-conversion-kits5/ch33538.html Back to your original question, that spindle will fit any control arm that fits a stock spindle. Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 This one is a double diaphragm, hopefully it's enough. Haven't bought A arms or coilovers yet. Wasn't sure if it will need a special setup. To get a good alignment! Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 28, 2022 Author Share Posted July 28, 2022 Any suggestions on good A arms at a reasonable price? That will work. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted July 30, 2022 Share Posted July 30, 2022 The upper control arms need to add caster; not all of the no-name control arms do this. Having around 5* of positive caster is the difference between the stock handling and performance handling. I'm running Summit Racing 'premium' control arms, which look to be a whiteboxed version of the old Ridetech design. If you're running coilovers I would recommend lower control arms made specifically for coilovers instead of springs as they allow a coilover with greater travel. QA1, UMI, and Ridetech all make arms designed for their coilover systems and they're all around the same cost. I also have tall balljoints in the upper and lower. The tall upper balljoints fix the camber curve caused by the stock spindles being short. The tall lower helps with bump steer and lowers the car. For the rear I would recommend a kit that either reinforces the stock shock mount or doesn't use it at all, like the Global West system. If you use the upper shock mounts I would get a stiffener bar to tie them together. The cars weren't really made to support the ride weight on the upper mounts. You want a good performance alignment, avoid any shop that wants to align the car to stock specs, as those are for bias ply tires. You want as much positive caster as possible, 1/8" toe in, and -.25 to -1.5 degrees camber per Ridetech. https://www.ridetech.com/tech/suspension-tuning-guide-high-performance-vehicles/ Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 30, 2022 Author Share Posted July 30, 2022 Thank you so much for the info! That helps a lot. Will all this, still apply to 2" drop spindles? Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted July 30, 2022 Share Posted July 30, 2022 With the spindles in that kit, yes. Most of the tubular control arms are made to work with stock or tall spindles. The tall ball joints give the same benefits as a spindle that's 1" taller. Quote Link to comment Share on other sites More sharing options...
Energizerlehman61 Posted July 30, 2022 Author Share Posted July 30, 2022 Okay, makes sense. Thanks again, for all the pointers! Guess it's time to spend some cash. Have a great weekend! Quote Link to comment Share on other sites More sharing options...
