Fgmcc grille badge
It should have comexwith the 2 studs, I used a piece of 1 inch aluminum stock I got at hardware store. The reason I used aluminum uas to elongate the holes a little because the studs were in a little bit of an angle. I still have it around here somewhere if you need a piece of it.
I used some really large washers from the hardware store which works on the 70/71 grilles pretty well. For a 72 grille you likely need to do a larger piece of metal/plastic as the grille openings are larger.
I’ll let you all know in 3 more years when I get my 5 year FGMCC cherry popped. It’s gonna seem like an eternity until then ..(Sob 🥺😭).
28 minutes ago, willie said:
Goes faster than you think Glen!!
I’ll bet it does. And at least I’ll be entertained by the car of characters here in the meantime.
Whatch you talkin bout Willis?
  • Haha 2
I did like Steve did a piece of aluminum behind the grill.  Soo I will have to get another piece for my 10 year badge
I used a piece of 3/8 inch plexiglass from an old wind chime. it was a round piece a little smaller than badge, drilled easy so i could elongate the holes.
