Crom Cruach Posted August 19, 2022 Share Posted August 19, 2022 what can I safely delete from the emissions system without messing up the operation of the car? I have removed the TCS solenoid and put the vacuum direct from carb to distributor can I remove the fast idle solenoid? how about the temp sensor on the block? is there anything else? Quote Link to comment Share on other sites More sharing options...
Scott S. Posted August 19, 2022 Share Posted August 19, 2022 The temp. sender doesn't have much to do with emissions.... But it does operate the gauge/warning light, so don't mess with that. I believe the only other thing you can safely remove is the charcoal canister and hoses, remember to plug everything off . As for the fast idle solenoid, I'm not sure.... It's been a long time since I played with a Q-jet. You are planning an "open element" air filter when you switch to header exhaust, yes ? Quote Link to comment Share on other sites More sharing options...
Scott S. Posted August 19, 2022 Share Posted August 19, 2022 4 minutes ago, Scott S. said: The temp. sender doesn't have much to do with emissions.... But it does operate the gauge/warning light, so don't mess with that. I believe the only other thing you can safely remove is the charcoal canister and hoses, remember to plug everything off . As for the fast idle solenoid, I'm not sure.... It's been a long time since I played with a Q-jet. You are planning an "open element" air filter when you switch to header exhaust, yes ? P.S. I don't remember if your car is air conditioned, but removing the fast idle solenoid will effect it if you do have it. Quote Link to comment Share on other sites More sharing options...
Dtret Posted August 19, 2022 Share Posted August 19, 2022 My question is why? Back then that stuff didn’t do anything but reclaim fuel vapors. Now if you have the smog pump, tubes, etc that I can see. Cleaner engine compartment and don’t play nice with headers. Save the take off parts. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted August 19, 2022 Share Posted August 19, 2022 I agree, the TCS controls the transmission and has nothing to do with emissions. I would leave the fast idle solenoid alone and the temp sensor is needed if you have gauges or you want the light to work. Quote Link to comment Share on other sites More sharing options...
Crom Cruach Posted August 19, 2022 Author Share Posted August 19, 2022 Thanks gents. The TCS solenoid because mine is broken, and it just seems tidier and simpler to bypass it. I don’t see any advantage in keeping it except for a restoration. It seems like an afterthought. I figured some of the other emissions stuff might be the same. sorry yeah mines got air con and is auto, 350. 1 Quote Link to comment Share on other sites More sharing options...
Crom Cruach Posted August 19, 2022 Author Share Posted August 19, 2022 30 minutes ago, 1970mcss said: I agree, the TCS controls the transmission and has nothing to do with emissions. Isn’t the purpose of it to reduce emissions by restricting vacuum advance until 3rd gear? Quote Link to comment Share on other sites More sharing options...
1970mcss Posted August 19, 2022 Share Posted August 19, 2022 Paul, this is what i found: The TCS (Transmission Controlled Spark) relay was introduced during the 1970 model year. This normally closed relay opened the TCS Solenoid to provide full vacuum to the distributor when the engine was cold. 1 Quote Link to comment Share on other sites More sharing options...
