Scott S. Posted August 29, 2022 Share Posted August 29, 2022 Ever since I got Montelishi back from the painters,(last year) the dome light didn't work. The console and other lights do but not the dome. (in any mode) I replaced the bulb, fixture, and traced the wires.... but no luck. Six months ago I switched my dash lights to LEDs, and was happy to have the visibility improved. Anyways, a couple weeks ago, the "inst lts" fuse blew, and I replaced it with one of a slightly higher amperage. Everything was fine. AND..... The dome light worked.... ???? Last week, the dome light stopped working again....... (scratch head) I needed to run the in the dark the other day, and when I turned the lights on, the dash lights blew another fuse. Got me thinking I need to go to a higher amp'd fuse for the LEDs. But when I got home, and opened the door, the dome light is working again... (more head scratching) I've looked at the wiring, which appears O.K., but now I'm thinking it might be the light switch itself...... Any ideas ???? Quote Link to comment Share on other sites More sharing options...
1970mcss Posted August 30, 2022 Share Posted August 30, 2022 I changed to all led and no problems. The voltage should be less with led. I would think maybe the headlight switch. I wouldn't know what you could check Quote Link to comment Share on other sites More sharing options...
1970mcss Posted August 30, 2022 Share Posted August 30, 2022 Or maybe check the ground wire at the switch?? Quote Link to comment Share on other sites More sharing options...
cbolt Posted August 30, 2022 Share Posted August 30, 2022 So no dome light in either mode, door open or using the potentiometer on the headlight switch then? I want to say the headlight switch feeds the door switches power, but that is from memory and not looking at a wiring diagram Quote Link to comment Share on other sites More sharing options...
Scott S. Posted August 31, 2022 Author Share Posted August 31, 2022 Only when the fuse is good.... When the fuse fails, I get both modes working. I don't believe the light switch and the door switch share the same circuit..... Just send power to the same device/light. Which is why it's strange that a failure only effects the dome light and not the rest. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted August 31, 2022 Author Share Posted August 31, 2022 21 hours ago, 1970mcss said: Or maybe check the ground wire at the switch?? That could be..... Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted August 31, 2022 Share Posted August 31, 2022 The door pin switch is the ground. When the door opens, the switch completes the ground and the light comes on. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted September 1, 2022 Author Share Posted September 1, 2022 That part works.... As well as twisting the headlight switch. The dash lights only effect the dome light..... I replaced the fuse yesterday with a higher amperage one. Dimmed the dome light, but seemed to stay on. I'll see how long this one lasts, but it appears that my LEDs are drawing more amps than I thought they would. Quote Link to comment Share on other sites More sharing options...
