Canuck Posted September 17, 2022 Share Posted September 17, 2022 I’m test fitting the sport wheel in my 70 Monte before I paint the hub. I had the standard 1970 wheel before. I can’t figure out how the horn hooks hooks up. I assume the spring simply contacts the metal tab sticking out of the horn assembly? Do I simply need a longer spring in the little tube on the column to Make contact with this tab? Is there something else involved here? (Note I just have a couple temporary screws holding the wheel on the hub. I don’t intend on driving it like that.) Quote Link to comment Share on other sites More sharing options...
Canuck Posted September 17, 2022 Author Share Posted September 17, 2022 Is this what I’m missing? Quote Link to comment Share on other sites More sharing options...
Dtret Posted September 17, 2022 Share Posted September 17, 2022 That’s it I believe. Should be the same as your 71 with the NK wheel. You could temporarily borrow it from that to check. 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted September 17, 2022 Share Posted September 17, 2022 1 hour ago, Canuck said: Is this what I’m missing? If I remember correctly, that should be it Aaron. Also check out Ground up website with the 70 steering wheel kit, I believe it's all the parts layed out. 1 Quote Link to comment Share on other sites More sharing options...
