Traveler Posted October 23, 2022 Share Posted October 23, 2022 Replaced the clock with the Parts Store quartz model, after a few days it has gained 40 minutes(running fast), has anyone experienced this? I have been dealing with a dashboard grounding issue, gas gauge going below empty with the headlights on, could this be symptomatic of the same problem? Quote Link to comment Share on other sites More sharing options...
cbolt Posted October 23, 2022 Share Posted October 23, 2022 Could be. My clock for the parts place works very well and only loses a few minutes every month or so. Of course you won't know for sure until you get the other stuff sorted as I do believe if the voltage going to the clock is high it will run faster than it should. Quote Link to comment Share on other sites More sharing options...
LS65Speed Posted October 23, 2022 Share Posted October 23, 2022 13 hours ago, Traveler said: Replaced the clock with the Parts Store quartz model, after a few days it has gained 40 minutes(running fast), has anyone experienced this? I have been dealing with a dashboard grounding issue, gas gauge going below empty with the headlights on, could this be symptomatic of the same problem? Why don't you connect the clock to an external 12 volt battery that is not otherwise connected to the car. Only supply power to the new clock and eliminate all other potentials problems / issues. If it keeps time correctly you know there is an issue in the circuitry of the car as opposed to something being wrong with the clock. Quote Link to comment Share on other sites More sharing options...
Traveler Posted October 23, 2022 Author Share Posted October 23, 2022 good suggestion, it may end up as a canary in a coal mine Quote Link to comment Share on other sites More sharing options...
LS65Speed Posted October 23, 2022 Share Posted October 23, 2022 6 minutes ago, Traveler said: good suggestion, it may end up as a canary in a coal mine Unfortunately if the clock works right during the test you come away w/o knowing what the issue is within the car. Quote Link to comment Share on other sites More sharing options...
cbolt Posted October 24, 2022 Share Posted October 24, 2022 20 hours ago, LS65Speed said: Unfortunately if the clock works right during the test you come away w/o knowing what the issue is within the car. But a good place to start would most likely be in the gas gauge/headlight switch issue. The idea of checking the clock straight from a battery source is a great idea but regardless of the result I would dig into the headlight switch issue quickly. Sounds like a printed circuit board problem to me. 1 Quote Link to comment Share on other sites More sharing options...
Traveler Posted November 7, 2022 Author Share Posted November 7, 2022 Clock worked fine after installing another ground. I may have set it wrong to begin with, if my memory serves me correctly I removed my watch as I didn’t want to scratch it up working in confined spaces, 1 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted November 7, 2022 Share Posted November 7, 2022 As Jim stated , a good starting point would definitely be the printed circuit board . That would be a rather common issue with vehicles this old. Quote Link to comment Share on other sites More sharing options...
stangeba Posted November 7, 2022 Share Posted November 7, 2022 I just checked and my clock is off (fast) by 1 hour today. This spring it was off 1 hour also but it was slow. 😁. (Sorry, I had to) 1 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted November 7, 2022 Share Posted November 7, 2022 Too funny 🤣 Quote Link to comment Share on other sites More sharing options...
