O E M 3:31gears 13-43. Made 3-69
Joe,
If I remember correctly, I do have stock 2.73 gears factory posi rearend and I can only go up to 3.08 ratio due to the carrier itself? To go to 3.08 or up to 3.73 ratio I'll need the carrier type that fits that ratio, correct?
55 minutes ago, 72 Monte Carlo said:
Joe,
Not sure which 'Joe' you're asking, but yes, you are correct. You'd need a 3-series carrier to use the 3.31 gears listed.
