Dtret Posted January 22 Share Posted January 22 Doing some wiring repair today. I’m trying to find out where the main wire connects. Nothing definitive in the books. Two wires come off the jug, the white goes to ground and the black w/ purple tracer is in question. I’ve found 3 different options. 1. Hook to horn relay, the wire is way to long for that. 2. Scotch lock connector to black wire on wiper motor. 3. Run back through firewall to fuse box, no holes for that. So I’m thinking option 2. But there is a plug right by the wiper motor plugs that is black with purple tracer. I didn’t think it was a plug and play option. But I also cannot find a use for that plug. Pictures attached. If someone has this option let me know. Thanks If I can put an end on the wire that would be great. Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 22 Share Posted January 22 I found this, may give some insight? I'll check the Fisher Body & Assembly manuals in a bit. https://www.chevelles.com/threads/windshield-washer-fluid-level-monitor.372041/ EDIT: If you have a 1970 Factory Assembly manual, go to option CD2, page 518 -523. Couldn't find anything in Fisher Body & Service manuals. Quote Link to comment Share on other sites More sharing options...
1970mcss Posted January 22 Share Posted January 22 Dennis, I did some research on the extra wire a while ago. What we came up with, was there is a jumper wire that goes to the idle control solenoid from that connector. Other forum members and I could never prove that the 1970 454 ever used that solenoid. Willie lent me a bracket that we thought would work for our cars. Dan Janes (overdrive) fabricated a bracket and I found a solenoid on line but it really didn't help. I have it and the harness if you need them. I hope that helps Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 22 Share Posted January 22 Dennis, on mine, one of the wires goes to the wiper motor assembly plug. The washer bottle monitor is only active when the wiper motor is running. rob Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 22 Author Share Posted January 22 8 minutes ago, Rob Peters said: Dennis, on mine, one of the wires goes to the wiper motor assembly plug. The washer bottle monitor is only active when the wiper motor is running. rob Thanks Rob. If you happen to get out to the car in the near future snap me a picture, or I will check it out in Carlisle. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 22 Share Posted January 22 I have to go to the storage garage soon to pick up a set of metal shelves to take out to install at my son's house. I will try ro remember to look when I go there. rob Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 23 Author Share Posted January 23 2 hours ago, Rob Peters said: I have to go to the storage garage soon to pick up a set of metal shelves to take out to install at my son's house. I will try ro remember to look when I go there. rob Thanks. No rush really. I can look when we’re in Carlisle. Quote Link to comment Share on other sites More sharing options...
DragCat Posted January 23 Share Posted January 23 I never messed with mine, I checked all my engine bay pic's but nothing past the top of the jug as far as wiring 🙃 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted January 23 Share Posted January 23 On mine, the previous owner rerouted the washer lines to a new aftermarket pump. But he used the same wiring harness. The black/purple wire ties into the power to the washer wire... looks like a factory connection,(like a rubber wrap) and the low fluid light comes on only when I turn on the wipers. Seeing as it was only on the '70's, I'm wondering if it wasn't and engineering afterthought ?? 1 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 26 Share Posted January 26 Wires to wash bottleWirWires at lampWires at intermediate plug Blue wire at intermediate plug Black wire awith yellow trace at intermediate plug Wires from intermediate plug to the wiper motor plug 4 Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 26 Author Share Posted January 26 Thanks Rob. I really appreciate that. Great pics and explanation. I will get home and do some investigating and post up what I find. Thanks again. Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted January 26 Share Posted January 26 On 1/23/2023 at 1:15 PM, Scott S. said: Seeing as it was only on the '70's, I'm wondering if it wasn't and engineering afterthought ?? No, it wasn't an afterthought. This option and the fiber optic light monitoring option was also available on other Chevrolet models and maybe other GM cars but I think after 70 models it was discontinued with Chevrolets. I do know it continued with caddy's rob 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 26 Author Share Posted January 26 Rob, thanks again for the pictures. Apparently you have the desired plug and play setup. I didn’t get so lucky. I have the scotchlock edition, not so desirable. But the wire wasn’t spliced into the harness, it is attached at the wiper motor. Ugh. 1 Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted January 27 Share Posted January 27 I read somewhere , maybe even this site that the scotchlock version was the dealer installed one. That was how my 70 was and it is not on the build sheet so was added later by someone. 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted January 27 Share Posted January 27 55 minutes ago, Grant MacPherson said: I read somewhere , maybe even this site that the scotchlock version was the dealer installed one. That was how my 70 was and it is not on the build sheet so was added later by someone. Maybe it depended on which plant assembled the car ??? Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 27 Author Share Posted January 27 Also interesting to add, the wires coming out of the washer bottle light plug are different than Rob’s. It still has two but one is white and short, which has a ground that just slides on the fender ridge, and the long black w/ pink tracer that goes up to the wiper motor. Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 27 Share Posted January 27 57 minutes ago, Dtret said: Also interesting to add, the wires coming out of the washer bottle light plug are different than Rob’s. It still has two but one is white and short, which has a ground that just slides on the fender ridge, and the long black w/ pink tracer that goes up to the wiper motor. Possible evidence it was dealer installed maybe? Scotchlock connector, easiest way to wire the reservoir (time is money, tech did it quickest way possible)? 2 Quote Link to comment Share on other sites More sharing options...
Dtret Posted January 27 Author Share Posted January 27 Very possible dealer install. But I’m going to go the same direction, minus the scotch lock, something like the photo attached but I need to find it in old school connections so it looks correct. 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 27 Share Posted January 27 I have the Packard 56 terminal kits here if you just want to use factory type connections. Quote Link to comment Share on other sites More sharing options...
DragCat Posted January 27 Share Posted January 27 I don't know if it makes a difference, but it looks like mine has 3 wires at the cap. Quote Link to comment Share on other sites More sharing options...
DragCat Posted January 27 Share Posted January 27 43 minutes ago, jft69z said: I have the Packard 56 terminal kits here if you just want to use factory type connections. I don't recall a Packard sitting in your shop 🤣 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 27 Share Posted January 27 22 minutes ago, DragCat said: I don't recall a Packard sitting in your shop 🤣 Lol, there's 'Packard' in the middle of the pack there, Mark 😁 3 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted January 27 Share Posted January 27 1 hour ago, DragCat said: I don't know if it makes a difference, but it looks like mine has 3 wires at the cap. 2 are the light bulb wiring the other is the fiberoptic to the interior indicator. 1 1 Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted January 27 Share Posted January 27 1 hour ago, jft69z said: Lol, there's 'Packard' in the middle of the pack there, Mark 😁 Nice assortment indeed! 1 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted January 27 Share Posted January 27 48 minutes ago, MC1of80 said: Nice assortment indeed! Thanks, Tom. There's a LOT more in various other places, these were easy to take a picture of. Nearly 40 years in the Instrument/Electrical Industry, one tends to 'collect' a lot electrical terminals, zip ties, black tape, etc., etc., etc. 😁. You know yourself, it's nice to have that stuff, "In Stock". Below is some more of the smaller stuff I recently sorted, plus the hardware/Grade 8/Grade 5/Metric storage bins in the new building. Last week I started to add that third row of louvered racks for the bins to the right. Also the bottom pic part of just one wall of some more storage bins. The basement...forget it, a crapload more terminals, fittings, parts, pieces, etc.. (That Doug Nash 5-Speed shown is available if anyone is interested, includes the Hurst Comp. Plus shifter too.) 5 Quote Link to comment Share on other sites More sharing options...
