FrankOC Posted January 30, 2023 Posted January 30, 2023 Anyone that has done the swap, what did you end up doing with the ebrake cable? I'm thinking I can shorten the hook that holds the cable to the cross member and put a shoot sleeve on the ebrake adjustment to give a bit more room to tighten the cable. Quote
Scott S. Posted January 30, 2023 Posted January 30, 2023 My Ebrake cable runs along the driver's side frame past the cross member (even after I moved it back for the 200r4) and then ties in to the cross cable under the back seat floor. Not sure if there's a difference between years/models. Quote
FrankOC Posted January 30, 2023 Author Posted January 30, 2023 Got it, thanks Scott, I see what I need to do. Quote
