Tmac Posted February 2, 2023 Share Posted February 2, 2023 I read to set the car on the ground with all the weight on it before torqueing the control arm bushing bolts etc. i have no weight just a frame, any wisdom or just snug it and do it later? Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted February 2, 2023 Share Posted February 2, 2023 Not even snug, just tight enough so they don't fall out. You want the weight on it before you tighten them up. 3 Quote Link to comment Share on other sites More sharing options...
Tmac Posted February 2, 2023 Author Share Posted February 2, 2023 1 hour ago, cny first gen 71 said: Not even snug, just tight enough so they don't fall out. You want the weight on it before you tighten them up. Ok, that's what I'll do. Thanks! 1 Quote Link to comment Share on other sites More sharing options...
Dtret Posted February 3, 2023 Share Posted February 3, 2023 Interesting thought. We’ve all seen the assembly line photos of the bodies being dropped on the frames at the factory. Do you think gm used a simulated weight system that produced the final weight of the car when they put final torque specs in place? It would have been unproductive to go back and torque everything on final assembly. I agree the frame should be loaded but it makes me wonder. 2 Quote Link to comment Share on other sites More sharing options...
cny first gen 71 Posted February 3, 2023 Share Posted February 3, 2023 Interesting thought maybe they left everything loose then tighten it all at alignment time, just a thought. 2 Quote Link to comment Share on other sites More sharing options...
