Tmac Posted February 10 Share Posted February 10 Here's the next project. Swapping the open dif for a Yukon posi and some 3.42s. 9 Quote Link to comment Share on other sites More sharing options...
Michael Boyte Posted February 10 Share Posted February 10 You will definitely feel a major difference with that setup. One you are sure to enjoy !! 1 Quote Link to comment Share on other sites More sharing options...
DragCat Posted February 10 Share Posted February 10 Just throwing this in the mix for your fluids 1 Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted February 10 Share Posted February 10 Went from the original 2.56 open to same Yukon 3.42 you are putting in, like a different car, love it. Just have to add a few bucks to the tire and fuel budget! 1 Quote Link to comment Share on other sites More sharing options...
Scott S. Posted February 10 Share Posted February 10 33 minutes ago, Grant MacPherson said: Went from the original 2.56 open to same Yukon 3.42 you are putting in, like a different car, love it. Just have to add a few bucks to the tire and fuel budget! An overdrive transmission will help with the fuel bills. Quote Link to comment Share on other sites More sharing options...
420ponies Posted February 10 Share Posted February 10 (edited) First off, Welcome to the Club! Hat's off to all the Engineers in the Fleet of Trains throughout the Nation! I'm doing a "clone" Custom of my '72 . Just got all of the stuff to fill my 12 Bolt, ( Thank you Steve). BBC 427 / Turbo 400 ( low 1st gear), 3:73 posi-traction (Yukon), Excel Gears, Moser Street Axles. Adding Rear Disc Brakes. 28" Nitto Drag Radials for now. Should be right around 2,500 rpm's at 65 mph. Motor has been balanced, should run just fine. Like to hear what you're combo is. Before the latest upgrade,355cu.inch,420 HP, 2004R ,3:42 10 Bolt posi-traction, with same tires. It was fun, but I always wanted a 427 in it ! in it ! Edited February 10 by 420ponies Spellcheck 2 Quote Link to comment Share on other sites More sharing options...
Tmac Posted February 10 Author Share Posted February 10 1 hour ago, 420ponies said: First off, Welcome to the Club! Hat's off to all the Engineers in the Fleet of Trains throughout the Nation! I'm doing a "clone" Custom of my '72 . Just got all of the stuff to fill my 12 Bolt, ( Thank you Steve). BBC 427 / Turbo 400 ( low 1st gear), 3:73 posi-traction (Yukon), Excel Gears, Moser Street Axles. Adding Rear Disc Brakes. 28" Nitto Drag Radials for now. Should be right around 2,500 rpm's at 65 mph. Motor has been balanced, should run just fine. Like to hear what you're combo is. Before the latest upgrade,355cu.inch,420 HP, 2004R ,3:42 10 Bolt posi-traction, with same tires. It was fun, but I always wanted a 427 in it ! in it ! I've got a stock 350 with a TH350. 12 bolt with 3.42 excel gears, yukon posi unit. Still want a cam and intake upgrade this year but really struggle with all the numbers! LOL to much info out there. Quote Link to comment Share on other sites More sharing options...
Tmac Posted February 10 Author Share Posted February 10 6 hours ago, Grant MacPherson said: Went from the original 2.56 open to same Yukon 3.42 you are putting in, like a different car, love it. Just have to add a few bucks to the tire and fuel budget! What are you running for eng/trans setup? I wont mind the increased budget as long as the smiles go up as well! And Thank you for the Hats Off! Quote Link to comment Share on other sites More sharing options...
Grant MacPherson Posted February 11 Share Posted February 11 It is 70 SS, still running 454 and turbo 400 1 Quote Link to comment Share on other sites More sharing options...
