Power for rear defrost blower?
Cooltech
It is factory. I did trace the wires and found that it comes down by the fuse block and it has an inline fuse of who knows what amp and where does it get the power from. Lol
The '70 Monte Carlo Assembly Manual shows power coming from the ACC port on the fuse panel and going through the switch and back to the blower.  I can't tell from the '70 Wiring Diagram Manual if the power wire runs independently for that RPO C50 or if it is included in any cabin or rear lighting harness.
1 hour ago, Cooltech said:
Thank you MCFan!! I did see a pigtail half of a fuse holder but the other end had disappeared. Wired in a fuse and it works!!
Thanks !!!!
Great!  You're welcome!
