Canuck Posted April 15, 2023 Author Share Posted April 15, 2023 1 hour ago, stangeba said: I replaced the heater core in my 71 (NON A/C) and put some pictures together on the event that may be of help to you. I had over 100,000 miles and it needed much more work than yours. https://1971montecarlo.wordpress.com/1971-monte-carlo-no-a-c-heater-core-replacement-pics/ I’ve used those photos before. Great resource. This will be my 4th time swapping the heater core in a non-AC car. Quote Link to comment Share on other sites More sharing options...
Canuck Posted April 15, 2023 Author Share Posted April 15, 2023 I’m working in pulling the heater core and see a pen sticking out from the bottom of the dash. I pull it out and felt another one up in there as well. I decided to feel around for other stuff and felt what I thought was a little flash light but once I felt the rubber part I knew what it was. The cigarette lighter!! I was pretty excited when I found it. 6 Quote Link to comment Share on other sites More sharing options...
Canuck Posted April 16, 2023 Author Share Posted April 16, 2023 Swapped the heater core today. I would normally be scraping off all the gunk from the firewall and heater box and painting the firewall but with this car I’m trying to preserve as much originality as I can. 6 Quote Link to comment Share on other sites More sharing options...
willie Posted April 17, 2023 Share Posted April 17, 2023 Aaron i feel your pain, when i start back up on my 71ss that will be the first project.. Quote Link to comment Share on other sites More sharing options...
Canuck Posted April 24, 2023 Author Share Posted April 24, 2023 The air cleaner cleaned up nicely. The decal isn’t too bad for its age. 8 Quote Link to comment Share on other sites More sharing options...
TheBMan Posted April 26, 2023 Share Posted April 26, 2023 On 3/31/2023 at 3:37 PM, Canuck said: This car has the nicest unrestored 72 grille and rear trim I’ve seen. The bumpers have zero rust and chrome is shiny. The interior is in very nice condition but needs a good cleaning. The paint looks good from far. The doors close perfectly and it drives very nice. Beautiful car, Aaron! A nice grille and rear trim on a 72 is indeed rare. Be thankful because, as you probably know, it's ridiculously expensive to restore that grille; I was quoted $2500 to do the grille on my 72. 1 Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 26, 2023 Share Posted April 26, 2023 47 minutes ago, TheBMan said: it's ridiculously expensive to restore that grille; I was quoted $2500 to do the grille on my 72. Been there.....💰💰 The back piece isn't cheap to re-do either. 3 Quote Link to comment Share on other sites More sharing options...
Canuck Posted April 30, 2023 Author Share Posted April 30, 2023 Today was a very nice day. I added almost 100 miles to the odometer. Here’s a video of it warming up in the morning. IMG_0031.MOV 2 Quote Link to comment Share on other sites More sharing options...
Canuck Posted April 30, 2023 Author Share Posted April 30, 2023 I still haven’t had a chance to wash it yet but it looks good from a distance. 6 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 3, 2023 Author Share Posted May 3, 2023 I spent today cleaning the engine bay. It isn’t perfect but I did get rid of most of the grime on the engine. I might hit it again another day to make it even better. I installed new hood insulation too after washing the underside of the hood. 6 Quote Link to comment Share on other sites More sharing options...
willie Posted May 3, 2023 Share Posted May 3, 2023 Look Great before Aaron now she looks even better!!! 2 1 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 6, 2023 Author Share Posted May 6, 2023 Worked on replacing the wheel cylinders today as they were leaking. I managed to get the brake line loose without twisting the line. The passenger side is complete so far and will complete the driver’s side tomorrow. Check out the big GC on the drum which is the suffix code for a 2.73 rear end without posi. I assume this marking was to help the assembly line worker choose the correct rear end as indicated on the build sheet. The GC marking is just on the one side. 8 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 12, 2023 Author Share Posted May 12, 2023 I finally broke down and decided to change the radiator hoses. I’ll keep the original hoses with the car though. I also replaced the heater hose that was a little short in my opinion. Looks better now. 6 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 13, 2023 Author Share Posted May 13, 2023 I finally had a chance to wash the body of the car and take some photos on the sun. 7 Quote Link to comment Share on other sites More sharing options...
willie Posted May 13, 2023 Share Posted May 13, 2023 Looks Great Aaron!!!! 1 Quote Link to comment Share on other sites More sharing options...
Cooltech Posted May 16, 2023 Share Posted May 16, 2023 Nice job Aaron!! Looking Good!!! 2 Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted May 17, 2023 Share Posted May 17, 2023 So factory painted roof? Same color as car. I like it that way. Seen you said same code bottom and top. 1 Quote Link to comment Share on other sites More sharing options...
714024SPEED Posted May 17, 2023 Share Posted May 17, 2023 Looks great !!! Love the original paint markings ,lots of information can be learned from such an original car. 3 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 17, 2023 Author Share Posted May 17, 2023 10 hours ago, Jared Richey said: So factory painted roof? Same color as car. I like it that way. Seen you said same code bottom and top. Yes, I was able to confirm with the line sheet and GM Canada documents that it came factory all one colour with the trim. Paint code 6363 and has the D99 option code for the trim. 2 Quote Link to comment Share on other sites More sharing options...
Jared Richey Posted May 18, 2023 Share Posted May 18, 2023 14 hours ago, Canuck said: Yes, I was able to confirm with the line sheet and GM Canada documents that it came factory all one colour with the trim. Paint code 6363 and has the D99 option code for the trim. Nice that has to be rare. 2 tone paint is rare much less same color. Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 18, 2023 Author Share Posted May 18, 2023 I’m enjoying this car a little too much. I have put on 240 miles. The car passed its safety inspection yesterday and is now registered in my name. If a car is brought in from outside the province an inspection is required. Usually anything they find wrong during the inspection are things that should be fixed anyway. 5 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 18, 2023 Author Share Posted May 18, 2023 12 minutes ago, Jared Richey said: Nice that has to be rare. 2 tone paint is rare much less same color. Yes, pretty rare. From what I’ve read the single colour with the trim was only made in the Oshawa plant. I know of one 72 in Quebec and a 71 in Manitoba. 2 Quote Link to comment Share on other sites More sharing options...
Canuck Posted May 18, 2023 Author Share Posted May 18, 2023 Just because I ordered a 1972 FGMCC plate for it doesn’t mean I’m keeping it… 😁 2 5 Quote Link to comment Share on other sites More sharing options...
Rob Peters Posted May 19, 2023 Share Posted May 19, 2023 6 hours ago, Canuck said: Just because I ordered a 1972 FGMCC plate for it doesn’t mean I’m keeping it… 😁 Yeah, right!! rob 2 2 Quote Link to comment Share on other sites More sharing options...
willie Posted May 19, 2023 Share Posted May 19, 2023 Aaron, I am with Rob on this one!!!!! 1 1 Quote Link to comment Share on other sites More sharing options...
