Whons Posted April 1, 2023 Share Posted April 1, 2023 I had posted a more lengthy post on this. What I want to know is if I disconnect the TV cable on my 700r4 Transmission at the transmission, witch is already adjusted properly, is the link that the cable connects to in the transmission going to stay in place to reconnect? Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 1, 2023 Share Posted April 1, 2023 Only if you pull the link up and clamp it so it doesn't drop back into the transmission..... Otherwise, you'll have to drain the transmission and remove the pan to get at it. Quote Link to comment Share on other sites More sharing options...
Whons Posted April 1, 2023 Author Share Posted April 1, 2023 Scott, thank you very much. That's exactly what I wanted to know. I'll put some layers of tape on a small pair of vise grips and hold it with that. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 1, 2023 Share Posted April 1, 2023 The "needle nose" vise grips work the best. Quote Link to comment Share on other sites More sharing options...
Whons Posted April 1, 2023 Author Share Posted April 1, 2023 Yes, that is what I was planning on using. Quote Link to comment Share on other sites More sharing options...
