Blackhawk Posted April 24 Share Posted April 24 These are the seals that go on the inside of the rear quarter window opening. For those who have replaced these seals, where did you get them? I bought the seals from Metro Moulded (ALP 5002-R) thinking that if they fit a Chevelle they would fit the Monte Carlo. The car has notches that seem to correlate to the clips on the back of this seal, but the new seals have the middle clip in a different spot. My stock seals are usable, but they're a bit stiff and starting to split on each end. Quote Link to comment Share on other sites More sharing options...
Scott S. Posted April 24 Share Posted April 24 I got mine from Parts Place.... But yeah, you have to be specific to Monte. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted April 24 Author Share Posted April 24 Would you be able to find the number of the part from your order? I'm not seeing that seal on their site. Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 24 Share Posted April 24 I got the Soff Seal version from Summit, SS-5023. They were the same as what you got though, with only two clips. I ended up spending way too much time taking the extra clip off the originals and putting them on the new seals. FYI, because it's spring steel, they're brittle and break easily, when trying to pry open the attachment clips. Quote Link to comment Share on other sites More sharing options...
MC1of80 Posted April 24 Share Posted April 24 The Monte Carlo and Oldsmobile cutlass(formal roof) use the same piece. If the other suggestions don't pan out, try and olds parts place. Quote Link to comment Share on other sites More sharing options...
Leghome Posted April 26 Share Posted April 26 I bought some from I think Lutty's at Carlisle several years ago cannot remember for sure. Some of them have the metal clips, the ones I got did not and they do not seal properly, so I am in need of more replacements Quote Link to comment Share on other sites More sharing options...
jft69z Posted April 26 Share Posted April 26 On 4/24/2023 at 7:34 PM, MC1of80 said: The Monte Carlo and Oldsmobile cutlass(formal roof) use the same piece. If the other suggestions don't pan out, try and olds parts place. I got the outer seals from Fusick (the Olds place) at the time, but they didn't have the inners, with the metal clips. Unfortunately, they still don't seem to have the inners listed on their site. You'd think that would be a popular item... https://www.fusickautomotiveproducts.com/prodinfo.asp?number=OQW702 2 Quote Link to comment Share on other sites More sharing options...
willie Posted April 27 Share Posted April 27 Cody when i built my car i could not find them either. I bought used from Leo in resources section. He had them. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted April 30 Author Share Posted April 30 Thanks for the information. With the condition of my current seals I'll try some weather stripping adhesive on the cracks and recondition the rubber. Metro is now making the outers so maybe they'll have the right inners soon. Quote Link to comment Share on other sites More sharing options...
Blackhawk Posted June 25 Author Share Posted June 25 I spoke to Metro at Back to the Fifties today and they didn't think it would be an issue to make the Monte Carlo inner strips if I sent the originals since the rubber extrusion is the same as the Chevelle. I'm not holding my breath but we'll see. 3 Quote Link to comment Share on other sites More sharing options...
