TheBMan Posted April 29, 2023 Share Posted April 29, 2023 Hey guys, I have my hands in all sorts of projects on this car. Can someone with a small block/Quadrajet take a photo of their setup so I can see if mine matches? I'm trying to solve a problem where I can't get wide open throttle and I suspect the linkage or setup may be different. Photo of my setup attached. Thank you! Quote Link to comment Share on other sites More sharing options...
willie Posted April 30, 2023 Share Posted April 30, 2023 Hey Bryan my parts cars only have 2 bbls but i think the set up is the same. I will check tomm to see if there is a difference for you. 3 Quote Link to comment Share on other sites More sharing options...
willie Posted May 1, 2023 Share Posted May 1, 2023 Bryan on my parts car (2bbl) the only difference that i can see is the mounting bracket stands up (vertical) not like yours where it horizontal with the manifold. I will check my 72 with a 4 bbl tomm, ran out of time today. 1 Quote Link to comment Share on other sites More sharing options...
stangeba Posted May 1, 2023 Share Posted May 1, 2023 Here is my 71 but I added Speed Control so it has an extra bit of stuff. (Wish mine was as clean as yours!) 3 Quote Link to comment Share on other sites More sharing options...
1970mcss Posted May 1, 2023 Share Posted May 1, 2023 I notice that Bruce's accelerator cable is bolted to the hole closer to the firewall. Not sue if that would make a difference. I checked my cable and it is also on the rear hole. 1 Quote Link to comment Share on other sites More sharing options...
stangeba Posted May 1, 2023 Share Posted May 1, 2023 One thing to consider, if you can't reach WOT, is that the floor carpet + padding + a floor mat, may be too thick? I don't think I have ever checked mine for WOT in 52 years. Quote Link to comment Share on other sites More sharing options...
TheBMan Posted May 1, 2023 Author Share Posted May 1, 2023 1 hour ago, stangeba said: One thing to consider, if you can't reach WOT, is that the floor carpet + padding + a floor mat, may be too thick? I don't think I have ever checked mine for WOT in 52 years. Yep, I checked the carpet (and floor mat), it's not an issue. And, like you, I won't ever drive it very hard, but I do want to make sure that it operates the way it's supposed to. Quote Link to comment Share on other sites More sharing options...
TheBMan Posted May 1, 2023 Author Share Posted May 1, 2023 4 hours ago, stangeba said: Here is my 71 but I added Speed Control so it has an extra bit of stuff. (Wish mine was as clean as yours!) Thanks Bruce. I just finished restoring the engine bay, that's why it's so clean. 1 Quote Link to comment Share on other sites More sharing options...
TheBMan Posted May 1, 2023 Author Share Posted May 1, 2023 2 hours ago, 1970mcss said: I notice that Bruce's accelerator cable is bolted to the hole closer to the firewall. Not sue if that would make a difference. I checked my cable and it is also on the rear hole. I've had the connector in both locations without much difference. I think the reason is related to the kick down. Still trying to figure it out, I appreciate all of the feedback! Quote Link to comment Share on other sites More sharing options...
TheBMan Posted May 6, 2023 Author Share Posted May 6, 2023 Turns out the kickdown cable wasn't allowing wide-open-throttle. I wasn't aware that there is a built-in adjustment on the cable where it attaches to the mount. I got that adjusted properly, installed a new throttle cable and viola! 5 Quote Link to comment Share on other sites More sharing options...
jft69z Posted May 6, 2023 Share Posted May 6, 2023 1 hour ago, TheBMan said: Turns out the kickdown cable wasn't allowing wide-open-throttle. I wasn't aware that there is a built-in adjustment on the cable where it attaches to the mount. I got that adjusted properly, installed a new throttle cable and viola! Glad you got it working. Here's a snip from the service manual in case someone else runs into that problem. 4 Quote Link to comment Share on other sites More sharing options...
